When i first purchased my r33 in November of 2010 it was in a somewhat sad state of affairs, faded (and in parts peeling) gunmetal paint covered the majority of its vulnerable body.
The car itself was a 93 E-Ecr33 (that's right folks she's a type S :P) and like all type S cars was powered by the non turbo variant of the rb25 and backed by the odd 5 speed auto jatco box. So in short it wasn't exactly a speed demon.
It looked something like this when i picked it up (don't let the polish fool you the paint was bad): ITF6lf7.jpg
It wasn't long before i got sick of looking at the horrible flaking off paint and tool the car down to Steve at wrapture stylings and got him to wrap the top half of the car in black (god those rims are bad)
After getting sick of being teased left right and centre by practically everyone for the dinner plate chromies (18x7 +43 :/ ) I sourced a set of rims off boost cruising and a week later they were on the car (they look like Veilside Andrews, but are probley fake, I have no idea). Somewhere along the line I picked up a series 2 boot as well.
A few months past and after over 220k and multiple trips past that 7k mark on the tacho the poor little rb screamed no more and decided to spin one of the big end bearings, the car remained stationary for over six months while trying to source an engine and after eventually finding one was transplanted into the car over a couple weekends (with more beer consumed then I'd like to think health and safety would approve of). *note nismo sticker for more killerwasps
Using the forces of sheer luck the motor started and ran like a dream, this was followed shortly after with another trip down to Wrapture for a full body wrap in chilli red vinyl:
Which brings us to September 2012, when after a trip home from power cruise resulted in a very blown up auto and me stuck in 3rd gear limping home, by this stage you can imagine my frustration with this car. But, this broken gearbox became the catalyst that would eventually result in "The Abomination" (as dubbed by SAU Qld) being built.
Within weeks I had decided I was through breaking Nissan products and thought I'd start trying to break a few bits of GM gear instead. So it was off to eBay where I sourced a vz ls1 (which proved more costly then first imagined) and a 4l60e auto gearbox to be transplanted into my unsuspecting r33:
*part two coming soon
https://www.sau.com.au/forums/topic/422076-the-abomination-wtf033/
Obviously step one was getting all the old Nissan stuff out and test fit up what the GM motor looked like in the nissan bay which ended up with the car looking something likeeeee this:
From there engine mounts were fabbed up and the trans tunnel lightly massaged to accommodate the 4Ls larger bell housing:
Not long after the radiator was fitted and the gearbox crossmember fabricated under the car, at this stage a 3inch single piece tail shaft was ordered and turned up within a few weeks:
Aparently I have no photos of the tail shaft but it looks like a tail shaft lol.
We ran into issues with the fly by wire throttle body and eventually decided to convert it back to a cable throttle from a vt which intern ment a swap over to a vt ecu, we had this sent off to vengeance performance for what is basically a bandaid mail order tune until enough cash is there for a head and cam swap (and a decent tune) but for what it is it goes well ;)
A few weeks later the extractors were fabbed up as well as the rest of the system which consists of the headers into a y merge and then into a mandrel 3" system with a single four inch resonator and a 3" in twin 2 1/2 inch out rear muffler.
As the gear box has been manualised a B&M pro ratchet shifter was purchased and installed into the existing r33 centre console, again more "massaging" of the factory stuff and it fitted up without two many complaints ;)
I know I've kinda crammed this all into a pretty short process but the general idea is there, the wiring was done by home grown kustoms in Toowoomba and as the car sits now is all mod plated up and ready to attack the mean streets of Toowoomba (as soon as I'm off these damn p plates)
Future plans:
*built 4l60e/th400
*Porter heads
*Largish cam (something in the 23X range) + required accessories
*obviously a retune
*3200 stall
*racepak dash
*New coil overs as the current ones are stuffed
... The list is really endless, ill keep this thread up to date with how the car progresses :)
It's kinda hard to get a video as I can't "legally" drive it, I'll try and get some up soon.
But it definitely does go :)
Find a private road/property like i always do :)
They were hecticly bad, literally got laughed at by SAU people lol
And this is something new? :P
There is but only one criticism I have of your setup, and no, it's not the fact it's auto...
The radiator support, if your gearbox and motor setup was anything like mine, it means you're going to have to do the old split the gearbox and motor apart while in the car if you need to pull the motor out again... It's my only issue, I personally would have made that rail a bolt in piece...
And in saying that, it makes me want to finish mine off really badly :(
i can see why! can i take it for a spin next month when im up? :P
dont like the wing much either but thats my opinion! overall tho nicky boy coming along nicely :)
Yer I get a lot of hate on for the series 2 wing? No idea why, I still have to series one wing sitting around in the shed lol
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
