Quick question, I feel like I'm pushing through the middle to front of feet when squatting, how can I move it back towards my heels more?
I was also doing this.
To stop it I did the following;
I put the bar under my traps (low back position), gripped the bar really hard, went for a wider stance, turned my feet very slightly outwards, dropped from my backside as though sitting and then on the way up pushed from the back of my feet through the hips. This part was real important, had to concentrate on where to 'push' from. I also took my runners off and did it in socks as the runners were springing me up pushing me forward. I dropped the weight until I got used to the new technique. I find I don't lean forward any more and importantly don't push off the front of my foot.
https://www.sau.com.au/forums/topic/422559-squattin/page/9/#findComment-6955850
Lean back? Are you squatting high or low bar?
A wider stance may help shift it back.
Tried leaning back, nearly fell haha bar is as low as my shoulder allows me.
Feet are just wider than shoulder width and toes pointed slightly out
I wear flat sole shoes, runners are too unstable. I'll drop the weight and concentrate more next time, I push through my heels fine with just body weight.
I was tired last time I squatted and thats the only time I've noticed it so far, might have been a fatigue thing.
Will see how I go tomorrow I guess
https://www.sau.com.au/forums/topic/422559-squattin/page/9/#findComment-6956122
You wont fix that on the internet, if you live in Perth either go to Muscle Pit and see Henry or PTC and see Dan
One session will fix your problem
Am planning on going to ptc once my other issues are fixed, like I said I only noticed it on the one session and I was screwed from work.
I'll see what happens tomorrow, I thought I'd ask here to see if there might be something completely obvious I was missing.
(don't take that as me rejecting your advise, i know its worth its weight)
https://www.sau.com.au/forums/topic/422559-squattin/page/9/#findComment-6956255
OK posted here as per the suggestion.
Since adding the board under my heels I've gone backwards, without it I had hit 6 reps on the final set of a 3x8 routine and was working towards getting the 7th and 8th.
Then I added the board as my ankle still won't allow good form, have to have legs way out and feet angled to get down and it feels uncomfortable. The board allows a narrow stance and deeper squat but seems to have cost me power, I assume I'm now using slightly different muscles that aren't up to task.
First attempt with the board was only 4 reps and failed the 5th, tonight it was only 3 reps and failed the 4th (may have been the jog I did yesterday that made it worse as I'm trying to get my ankle back to being able to handle jogging again).
This video shows without the board ( this was the end of my session tonight, sorry it's slightly crooked). You can see wider stance needed and not heaps low. I add the board at the end but the next video shows it better.
http://youtu.be/NSz35PrSg-8
This is with a board.
http://youtu.be/ZQxTuEPXEkU
With board, side on. No idea why this one won't embed.
http://youtu.be/3Ad2UD18nkg
If there's nothing overtly wrong with form I'll just knock some weight off the final set and get the rep count up.
This is only 70kg on the bar, I usually start at 80, then go 90, then a bit over 100. Light I know but I'm not great at this yet.
Edited by ActionDan
https://www.sau.com.au/forums/topic/422559-squattin/page/9/#findComment-6970678
Just trying to get comfy, I'd have to watch the vids again but from memory I don't think my feet move as much with the board.
When I'm doing it in my session I don't think they move much.
After reading some more of your stuff I'm going to drop a little weight and go for 2x 20 reps to build a foundation as I had no squat experience before feb and my mechanics continue to change as my ankle gets better.
DL is much easier for me/the ankle.
https://www.sau.com.au/forums/topic/422559-squattin/page/9/#findComment-6971836
  • 3 weeks later...
Question for the more knowledgeable here.
My knees stay behind my toes at a regular squat depth (just below parallel), the deeper I go the more my knees track forwards until they go over at full depth.
Is this a problem in relation to form/flexibility? Or is this normal body mechanics?
Will this become a problem later?
https://www.sau.com.au/forums/topic/422559-squattin/page/9/#findComment-7003774
cant answer your question Shaun as I have no clue.
My squats have tacken a massive backward step. I just cant seem to improve on them.
I have good depth but weight is 60kg and not even by 10 reps, its a joke, really need to figure a way past this hump.
https://www.sau.com.au/forums/topic/422559-squattin/page/9/#findComment-7007477
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
