No idea I have a print out but it was just a local rubber joint that did it
I don't have the camer adjuster/ castor adjuster / ikeya shit in the front yet so once they are in ill get a proper alignment with some camber/ castor up front
sweet thanks
my whale is understeering like a bitch lately
which i think is a combination of tyre pressure and alignment
According to this bloke..
http://www.r33gt-r.com/2012/03/r33-gt-r-cold-climate-region-spec.html
There's an extra plug for the mirrors and the defroster button in the centre of the dash turns them on, maybe wait for a cold morning if you can't be bothered pulling the door trim etc off? :P
So slapped the rear coils in
When I removed the parcel tray to get to the top struts I checked the child restraints, normally you would have to unbolt then to pull the tray,
Talk about dodgy
Child anchorage points bolted to the speaker covers
Added to the list of shit that needs fixing
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
