I can't see why the surge tank would be a problem. You may not be happy with Brad but that doesn't make his aluminium corrode. Plus I've been running one of his tanks about 12mths longer than you without any issues, there are plenty of them out there.
I think you need to look somewhere else. Feel free to point and laugh if I'm wrong
everything has been replaced
and now i can trace the source of the shit due to the multiple reusable filters
and there is definitely gritty alloy like stuff coming out of the surge tank
either way i will pull it apart and find out if its the problem
and put a fuel cooler on it now
Brad had a bad habit of not cleaning out his well-crafted parts properly and maybe that could be your problem big fella. I would stick with the fuel you are using,,,it has to come good sooner than later.
I have a purpose built fuel cooler off an X5 3.0l Diesel that you can use tiger. I currently run one on my car and it works a treat. Here's some pics for your love.
Here is it fitted to my car
Nice and new straight out of the box,,,waiting for some R33 GTR sex.
Plumb this bitch straight into your return line and cool that fuel baby.
Cheers
Neil.
There are some fuel cooler pics on this page -
http://www.sau.com.au/forums/topic/358438-34geeteetee-daily-track-project/page-27
Not sure if its helpful or not.
Thanks for that mate, I looked before but gave up cause to many pages lol
So that is just a regular 23 row oil cooler with a custom air duct/protector ?
Looks very nice and neat :thumbsup:
Yep, it will need some relocation or modification if i ever get around to doing underbody aero stuff... Its not really copping any air due to the diff being in its face but the fuel pumps have been nice and quiet since its been fitted so its certainly doing something, since the issue has been sorted we have not bothered logging fuel temps etc...
Neils compact design is probably a lot more practical and obviously more cost effective :)
  • 3 weeks later...
so last track day i noticed that after a few laps she started to get lean
and after about 6 hards laps would develop a missfire
so naturally i though my fuel was clogging my injectors again
checked them at the track and seemed fine
had them flowed and they were fine
anyway the internets told me when e85 gets real hot it leans out
and i decided that my surge tank was running dry ( its only about 1 litre and a average design)
the insides of the cheap alloy had ben oxidising and running thought the fuel lines as well
old setup
ill stick it on my r31 i think as it loves fuel surge
so fuel setup number three was drempt up
biggest walbro you can buy for the intank
alloy 2.5 litre tanks( anodized so it does not corrode)
trusty twin o44's
booked in for the skynats at winton with two drivers and this thing drinks fuel so will go the flex setup so i dont have to buy 18 jerry cans
  • Like 1
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
