perhaps an Evo or Rexy would suit you better
Insane driving - GTRs are big heavy sons of bitches and rally courses will always be challenging for them
But after seeing your driving style you seem not to be afraid of bending that whale that takes balls.........big balls
I want to see more photage
Drive a wrx… lol… I don’t like snacking on cock like gonads
Jenna used to have a STI…. Had to beat that out of her system
Drive it like you stole it.. Realistically is 17k car with 17k of modifications ( the majority unnecessary and pure wank)
If I tank it into a wall I will slap the good stuff in a r34 gtr and do the same
When I tank it into a wall I will slap the good stuff in a r34 gtr and do the same
Fixed
If history is anything to go by, pizza and beer the night before equals no show to start line. Maybe I'm soft but then again, we do tend to coax the worst behaviour out of each other somehow. :lol:
Hard to believe, considering how mature we are the rest of the time hey?
Calsonic sounds like he'd fit right in.
...Ben
Fixed
Well I for one don't want you to tank into anything with that nice boat.
But please tank beers instead
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
