Sorry for the complete noob question but I wanted to be sure before I ordered them and can't find an answer on the site. I have a 2003 m35 250t rs4, are these the right model numbers for the QFM A1RM brake pads:
Front: http://gslrallysport.com/au/qfm-db1232a1rm-brake-pads.html
Rear: http://gslrallysport.com/au/brakes/brake-pads/db1509a1rm-qfm-a1rm-brake-pads.html
thanks! :)
Are you tracking the car?
A1rm are a light track pad. For street go for their HPX pad, and just ask for 350z NON brembo pads. Job done. Gsl rally sport are good.
Is there any disadvantage to getting the A1RM pad if doing little to no track use (other than cost)?
They will go through your rotors quicker, and will be less effective because you won't get them hot enough to be in their optimum working range.
If you are getting pad fade with HPX then you need to take it to the track. Remsa are also ok I've heard, and gsl are moving to them.
The REMSA's are brilliant; gsl reckon they're halfway between HPX & AR1M on temp range ,but nowhere near as hard on rotors as the AR1M.
No squeaks or shudder, just dusty.
I like 'em that way.
I'll be testing out the a1rms on the 180 on Tuesday. I've got a full set of them in, they need a good bedding in which I might do on the way down to Wakefield.
Should work well on a lighter car. I did have pad fade from the hpx on the track in the stagea or whatever be got in the back. To be expected after I purposely put some hard stops into them.
Everything above about A1rm's is correct. I really need to get them off mine, lots of dust , poor feel until I get some heat into them and I hate to think what they doing to my discs. However, I was very happy with the one track day I did. ( 10 min sessions at Marulan ).
Give GSL a call and be honest about what you want from your pad. If it is just for the street, just get a street pad.
Thanks everyone. very helpful advice, steered me away from a terrible decision! Ended up going with the HPX pads all around so hopefully they are as good as you all say haha
:cheers:
The HPX is a good daily/ fast road pad; just make sure you follow the bed-in instructions closely.
People seem to go bananas when bedding them in; overheat them and they squeal like a bitch. There is no need to do tonnes of stops from 100+km/h!
I did the ones on my missus car at no more than 60km/h in back streets, and they are quiet as a mouse; with great feel. Bugger all dust too.
GSL Rallysport are great to deal with as well; they had pads & rotors to me (Blue Mountains) from QLD, IN ONE DAY!
My HPX are squeal free and good feel, but dusty as all hell...
Must be the slotted discs making them do that... :whistling:
Less than 24 hours to me 45 minutes east of Melbourne..
I have hpx they stop awesome and virtually dust free. Mine do squeal like hell but maybe I didn't actually bed them right after what dale said
Shims are most important. Anything is going to squeal without shims. If they aren't installed properly, even in the slightest, you'll get squeal.
Every QFM pads have bedding in instructions in the packet.
Yeah I have learnt the hard way before.<br /><br />The advice I got from gsl was anti squeal paste between pad and shim - but not between shim and piston.<br /><br />Do you agree? <br />
It can't hurt.
I've used the stuff before, and had squeal, not used it and had no squeal. When you have the pads out, give them a small scrub on a concrete surface to take off the sheen. Helps them bed in a bit more.
Well i have put it between pad and shim, and on the other side of the shim also. I understand it just to be an insulating barrier, it doesn't stick or hold anything together. <br /><br />Will bleed them up and start the bed in process as per instructions. If they squeal I will be pissed. Ok on a tough stripped out racer or street car with one thing in mind , but on a luxury gt like a 350GT - ain't nobody got time fo dat!!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
