Thanks everyone, looking back at what I had planned I am really really happy with how it turned out, credit to Planned Signs at Minto who took this project as seriously as I did and make sure it was perfect. Looking at photos of the original car and models I think it's about as close I could get it to the original and I'm stoked
You coming trackday next month??
Doesn't look like it. Need some work done on the diff and gearbox. This is only the beginning :yes:
Was a nice car....now a very COOL car. Love the final touches...copies of period race cars often run the risk of being try hard BS shitboxes. Your's looks tough!
I know exactly what you mean. Most of the other replicas of his car I've seen looked like shit. A little attention to detail and a lot of assistance from some helpful people (especially from SAU) goes a long way!
Thanks again everyone who commented and pitched in with photos and logos and stuff. You guys are alright ;)
  • Like 1
Hey guys, after a set of rear bumper lights like these:
anyone got some spares laying about?
I'm currently contacting places trying to find a brand new set. will let you know if i have any luck.
Just got the car back from Award. Had the gearbox reco'd and replaced all the synchros, modded the transfer case and shimmed the rear diff with Nismo plates.
Diff feels super aggressive and awesome just putting it on the trailer, should make a big difference. Here she is hanging out the front of Award. These guys have done a really great job at an awesome price. Terry knows about GTR diffs and gearboxes, I wouldn't take it anywhere else.
1890500_839221409442389_6091326556419303
  • Like 5
Was at Trackday Club on the weekend and had a shocker. Missed the first two sessions f**king around with the catch can, went out and bent the HICAS lock bar, said f**k it and went out again lost boost pressure so we packed up and went home. Also couldn't get the motherf**king shift-i to work. Not a good day.
At least the car looks good
10500554_751963151563572_910845597172439
  • Like 1
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
