It's what's in the heart that counts. It's like moving Leon from Packenham to Toorak. He'd still be known as Leon from Packy.
I went to a house party in Packy the other day. The guy hosting it knew who Leon was. He's a local legend.
  • Like 1
Guys we need assistance
If you have friend a or 2 coming up with you and they could lend a hand that would be fantastic.
Link below
Cheers Wayne
http://www.skylinesaustralia.com/forums/topic/424957-deca-officials-volunteers-1st-june/
New diff is working awesome, though last night it started stepping out when I put my foot down in 4th on nepean hwy heading home. Still getting used to not single spinning everywhere :P
What are lock stops?
Why were you stalling? Just rip the hand brake and keep your foot to the floor :P Braaaaaaappp!
(for some reason) my car had/has a ridiculously small turning circle. I suspect it was rubbing on the inner guards and bogging it down when on the skidpan at speed. Anyway, it wasnt a happy chappy and my handbrake skillz need work too haha
Because the new suspension has external canisters, we were concerned the steering angle might cause the wheels to hit them. So we installed lock stops inside the steering rack to limit it.
Link below
Cheers Waynehttp://www.skylinesaustralia.com/forums/topic/424957-deca-officials-volunteers-1st-june/
Ok
It's serious time..
We need people to help run the day. What I'm looking for is for volunteers to help run the morning events .
We have the
Skidpan.....need 3 people
Mini..3 to 4 people
Long..5 people
At this stage there is only Anna and myself..
So if you have mates/ girlfriends/ boyfriends / mums or dads coming up they will be helping out ..
If they don't want to help out leave them at home.
Cheers wayne.
  • Like 1
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
