What tyres you running??? Find me a set in 245/40/17 for $50 a corner max and we will see who is quicker. Don't car about skid pan, its all about the back tracks. (That's what I pay for deca semis ;))
Keep your old lady fantasies to ya self!
She doesn't go for guys that punch dogs anyway - seriously man that was f**ked up.
And it dosent stop at dogs... The elderly, women, children... whatever
  • Like 1
Hey guys,
I was just wondering if its ok to use cable ties to mount my fire extinguisher?
I read somewhere on here that that's ok.
Also I sent in a cheque to pay for my entry as I don't have a computer. Hopefully you received it Ryan.
  • Like 1
Hey guys,
nope ext has to be mounted with bolts to metal, not cable tied, no self tapping no having a passenger holding it for you!!!
sorry but dems the rules that AASA require from us.
just use one of the bolts at the base of the back seat and make it fit.
oh and put on passenger side so you can reach it...
Hey guys,
75% of wheel nuts need to be tight or attached. Same with seat mounts. Decent oil leaks are preferred so we can find you when you don't make it to the finish. Basketball court is optional on timed runs and always line up straight after you finish a battle.
You coming along or you a big girl?
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
