Thumbs up to the organisers. Day went well even with the less than ideal weather. Got a better idea of what the Prius will do if it rains at PI but really hoping it doesn't.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
