seeing as i dropped my turbo today heres some of Scottys work
look at that entry path, how could it not work well....;)
That's some mighty fine workmanship there. Exactly as you stated how could that NOT work. Perfect gas flow both ways. Why would you bother running a waste gate off your manifold when you can have that :)
heres mine for a single gated TS
wastegate pipe TS housing
20130508 123417
Edited by AngryRBGTX
haha yep sure is, its mounted on the 0.82TS gt30 bolted to a low mount 6boost, extreme stealth :ph34r:
i edited post, heres a pic from the top ...
No it's off the housing Artz, so you found someone up there to fab my design ideas Mark? Looks great. Had it tuned yet?
I did a T67 this way not long ago, no results though. Using the gate as the bend makes the path as straight as it can be, especially if plumbing the screamer back.
Yeah i decided to just leave it in at a workshop, came highly recommended by MTQ, very appreciative of your fab ideas scotty, and to ARTS
for the Xspurts injectors ideas, :cheers:
will be a few weeks before its tuned, still got a few things to do yet but hopefully will start it up for the first time on the weekend :woot:
Heya Mark,
Does the dump/turbo setup touch any of the stock A/C lines or the A/C drain rubber hose? I've seen a few setups that end up toasting the A/C rubber drain..
and low mount looks teh secks... MOAR photos :)
its not touching any A/C lines but its close as you can see in the pics, i think insulating all the wires and a/c lines will be a good idea, im not finished yet,
going to do a proper heatshield over the manifold and then a big cold air intake box and feed plus painting all pipes black,
to me , it almost looks kind of stockish looking? or kinda close as these mods can be, the 4inch intake is a beauty :whistling:
Heya Mark,
Is that the manifold thats a real PITA to fit ?
Cheers A .
I don't see any probems,
although the ceramic coating was a slight PITA, had to sand it off in places to get the housing back on.. :closedeyes:
By the way, I've got my wastegate mounted on my housing as well. Unfortunately it's not welded on as well as the one Scotty did, mine is at 90 degrees to the exhaust flow. It still holds boost in a perfectly flat line though, no creep. Will upload a graph on Tuesday/Wednesday when it is hopefully holding ~23psi dead flat ;)
that's interesting that it works on a 90deg angle, my tuners had situations like that where 6boost manifolds have had the gate at 90degrees and it will start boosting up to a bar with the gate not even attached but then theres guys that have zero problems, i didn't want to take any chances so i put the gate on the housing to make sure.
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
