I'm not in the business of doing welding related fabrication work
Sorry, I thought you were by your statement.
Quote: And if any one wants their manifold to be done. The cost for doing so is $300 and our 50mm HPVA gates are $350 in additional.
The 430kw result was, for the 10th time, an RB25 in a 33gtst. The engine has cams and runs a gtx35 off an unmodified manifold, with a shitty 3 inch exhaust and a screamer on United e85. I have no idea where you got VQ from, mine is the highest output VQ25det I have heard of, and it's stuck at at 350kw due to the auto box.
Means I do the engineering work, and supply the gate. You are doing the welding. Which is why I've been talking to you about making external gate running out of stock exhaust manifold, and I don't think there is more then $200 of welding involved.
Well, if that is a GTX3582 then that is a tinny amount of power. I still want to see the dyno paper.
Just because it 430 kw doesnt mean the manifold wasnt a restriction as if the person used the ssme setup with a proper manifold he would obviously net good gains with that turbo.
The manifold of a Rb25det could be significantly different to a M35 Stagea which should be more modernised.
There is a 15 KWs gain just by swapping stock exhaust manifold to some thing properly made. The restriction on it is before the entry of the turbine housing, of where three collectors merges into one. By adding an additional collector at that point reduce excess heat, and pressure as what we can see in the change in upper power and torque curve.
The overall gain of this modification have made a difference of 31kws, with a final result of 376rwkws that is some thing that no one have ever made using turbine housing mounted external gate setups on standard Rb25det exhaust manifold. This is also my first attempt, there are few things that could be done improving upper rev range torque.
Scotty: it is probably worth while making a jig and properly fabricate stock RB exhaust manifold in similar manner to what I've done. With proper external gating setups, the factory exhaust manifold could be performing at same level as some of the popular aftermarket high mount setups.
so i would expect a 15kw gain from a external gate on the stock exhaust manifold? its a HKS2535
it would also help with the boost issues as well. it drops 5psi by rev limiter.
people have done the external gate thing before on 2535's.
I think there is a bit to be gained but prob not worth the fking about unless you can do it urself. Its a small turbo which is going to struggle to flow much more air from that compressor wheel methinks... A good EBC and actuator gets the most out of the 2535 (had one myself. good little turbo :))
Looking back to my result, actually this external gate setup managed to match my Brae high mount manifold's result in exception of slightly lower in upper range torque.
G3's result which share the same compressor as the OP6 high flow.
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page-355
So this setup is enough to max out your 2535's compressor flow.
Scotty is coming over this weekend and we will be looking to get all the plumbings properly made and jigged, before offered as a cheap and effective service.
Before people get too excited by power gains hanging an external wastegate off the oem rb25 manifold.
Please note, it may be fine on the street, but on the track oem mani's tend to crack/warp eventually - done this twice so far.
Mind you if it ends up being a cheap welding mod, then it may work out ok.
Ps. If someone made a better steam pipe log living in that area using oem heat shield, this could be a great mod :)
So what will make a turbo come on boost faster ? A manifold with smaller internal volume ?
Yes it does. Stock manifold has better down low response and torque using the same turbocharger.
Reference:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page-298
i prefer it on the housing... its the bottle neck.
This is my GT3582R setup bought from ETM.. nothing but issues and wouldn't control boost. If its plumbed into the right place on the housing should work but mine was obviously not in that basket. Granted mine is high mount blah blah not on a standard config. As soon as I changed to conventional gate of manifold configuration problem solved
It is tapped off very late on the housing, well after the nozzle, still I would have expected it to work well enough, if the inside was cleaned up with a die grinder after welding. There have been no issues with boost control on any of the modified housings I have done, and no cracking on the mild cast, or investment cast stainless housings. Even after 5 years and countless track days.
I noticed you weren't running switched boost pressure to the top port of the wastegate, that will help hold massive boost if that's what you were planning...
I had no need as I wasn't running an electronic boost controller so there was no need for a vac feed above the diaphragm. We eliminated all variables so it was just running gate pressure. took the .7 bar spring out and put a 1 bar spring in it, also tried vac feeds from the plenum and the compressor housing etc. Tried everything but the second it got to 4200rpm it would spike from 14psi straight past 35psi.
Every one of these I have seen done the waste gate feed has been different to mine. This was a kit supplied from ETM and I had no joy with it as I asked him what do you recommend and he said this configuration would give the best boost control however that was not the case I ended up selling the kit and moving on to another kit that worked wonders and never had an issue controlling boost.
Gate looks like its on a 90degree angle, probably why it didn't work.. if it were a half inch closer to the rocker cover it would of gave it the perfect entry to the gate..
Edited by AngryRB
Agreed, in that position it would almost flow backwards from the gate, similar to a paint spray gun. :P
Once gas has already accelerated to high velocity (such as in or after the nozzle in a turbine housing) it is much harder to make it change direction. Plus, the static pressure (or at least a good chunk of it) has been converted to dynamic pressure 9velocity) and there isnt actually any driving force left to make a 90° direction change. If you want it to turn 90° you have to do it while the gas is still as slow as possible.
Exactly why I binned the kit. Had nothing but issues with it from the day I bought it.
This is a mod a mate of mine is doing to his Ti R31 Skyline. GTX45 with Tial Rear housing, Tial 60mm gate and also a built RB30 single cam. He hacked into a $2700 rear housing as he couldn't plumb it from his manifold due to a 5 inch dump lol so had to go off the housing
he got it at cost price locally as he buys a lot of gear and a lot of GTX's through there. The turbo itself wasn't horrible but just sheer size of the GTX45 housing is what killed the wallet.
He has bought a mixture of GTX3071 and GTX3076's for various projects of his and the Tial rear housings were very reasonable. But this one was a killer lol
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
