hey i love my car but i love my girlfriend more and we need money to help with getting her visa and everything to keep her here so i want to know how much i could sell it for
1996 Nissan Skyline R33 GTST S2
100,000kms
19" rims
Catback
Apexi Pod
HKS FMIC
Apexi RSM
Apexi SAFC
Turbosmart Type3 BOV
Turbosmart 2stage boost controller
Pioneer Flipout DVD player
Pioneer VDP Vehicle Dynamics Processor computer addon
GTR style wing
400r skirts
Bride Race seat
i have all original parts as spares as well
well thats roughly it so i judt want a rough estimate on what i could sell it for thankyou
https://www.sau.com.au/forums/topic/425473-what-is-my-car-worth/
condition is the big factor, and proof of history. Its worth as much as the buyer is willing to pay. =)
I paid 11k for mine in december with similar (slightly less) mods. But it is very clean condition and 130 000km. also got last 4 yrs worth of receipts. (inc major 100k service, coils, general expected repairs, etc)
There are heaps around in the 7-11k range.
Bit hard to say.
It's desirable as a road registered track car but "unknowns" still include...
* 100K Service done?
* What kind of rims?
* Engine cond?
* Suspension cond?
* Body cond?
* Service history?
...and the money you get can depend on marketing as well as the above, including what other members above have said!
Pics (as mentioned above too), can convince someone to at least come over and have a look!
thankyou everyone for your replies, i forgot to mension it has tein height adjustable coilovers, the rims are Lenzo, i change all the fluids, filters and plugs myself regulary, its an automatic which i forgot to mension as well, the interior is im immaculate condition
also have a 400r front bumper for it but it is slightly damaged so i put the stock one back on it, i also have a 3" stainless steel front/dump screamer pipe which isnt on it at the moment, it has nice new dark tinted windows and clear side indicators so its a lil dressed up and ive polished and dressed up just about everything in the engine bay so it looks nice, its silver in colour and has a factory sunroof, i will post some pics soon but thankyou for everyones opinions on prices i really really appreciate it
​^ that will very greatly hurt it's value & desirability unfortunately mate!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
