Hey guys,
Been looking at these turbos for quite some time and have been very impressed as most people are, I have a r32 with a built 26 with a gt3582 6boost and all the rest making 460rwhp, I spun a bearing now building a 26/30 and have my eyes on a super 94, my power goals are for over 500rwkw which I now the turbo is capable of, ive ordered a new 6boost mani twin scroll t4 and was thinking of going the 1.15 exhaust housing, I have a fair bit of head work done with big cans and gears, just wanted to put it past you guys before I lay the cash out.
Brad
Hi - sounds like you are on a mission for something pretty intense :D
The Super94 HTA is an awesome turbo, and as much as I'd love to see one on an RB - it's more turbo than you NEED to surpass 500kw, over 500kw is a broad term so if you mean anything over 500kw but with maximum response then the Super94 is more turbo than you need for the job.... being that its more a 600kw+ turbo when ethanol gets involved.
In saying that, I have been talking to someone with a Super99 HTZ on his 3litre Supra road car and he reckoned even that wasn't actually that hard to get to come alive once he was over 4000rpm and the Super94 is a reasonable amount smaller on the compressor. The short of it is I don't know exactly how responsive the turbo would be on a 3litre, I don't know of anyone who has used one and got it fully tuned on a 3litre yet but have absolutely no doubt at all it will go over 500kw with supporting mods to suit - I'm just not 100% sure what response you should expect compared to other turbos which will also get you in the 500kw range on E85, absolutely not saying it will be a laggy sack... just you will have one of the most responsive turbos you can get for it's target power range, let alone for the money - but if that power range is higher than yours then you may be sacrificing a bit of response.
Interestingly enough I actually had this conversation with someone a few days ago and am still soul searching whether I want to go the exact same combination on my own Skyline or not - and if I decide to build an RB30 it's one of the most likely options I'd go for. I've been in Skylines with comparatively sized (physically) turbos and motors and found them perfectly liveable for my tastes... and even if I weren't to use the full flow, I know I have something usable that isn't straining to make 500+kw and has the option of going full retard on occasion if I want to run a hero boost level. It just depends on your taste etc.
edit: You posted while I was writing my speel. AWESOME! I am really really keen to see how this goes :D I hope it turns out well, it's certainly got the potential to be a monster. Is it a GTR? Hopefully you have a strong motor, gearbox and big fuel system :D Damn that's shit timing with the pricing, they were still cheaper yesterday... I am sure.
Haha yeah should be alright, I checked yesterday they were $1875 then this morning when I woke up they were $1999 so I bought one now they are $2299, the car was a gts4 but now rwd, its going to be on e85, 5ltr surge with twin 044, 2000cc injectors, hks rail turbosmart reg, bottom end built by lewis engines and gavin wood putting it all together, still got other bits and pieces coming but yeah I agree in going the 600rwkw mark sounds more realistic
Running a gtr box still, I know its not suited but a ppg gearset is on the list or if I find another gearbox before the engine is finished, im not too worried about that now just sorting the engine out
  • 3 weeks later...
Got my HTA3076r the other day from a member on here.
Cant wait to get it on.. will be a month or so from it yet. but will post a spec sheet and results soon
Awesome, look forward to hearing how this goes - keep us updated :)
Was a built 26 running 18psi on bp98. It was pretty loose driving it then should be good fun with this new combo
It's going to be mental, would make for an awesome overlay for comparisons sake if that's possible! When are you aiming to have it going?
Ive just been ripped off on a rb30 shortblock so not too sure on when it will be going now. Fp told me it will take a few weeks to build the turbo so it should be ready to ship next week. I will be using different dynos and tuners.
I definitely have ear to ground on results, and also all ready to give people bad ideas if the opportunity arises haha :) I would have succeeded in one case, but the person needs a T4 housing... argh
  • Like 1
my mate is after this type of setup atm, but due to no results atm, has gone for a Precision 6466 T3 .82 on a rb30 sohc low mounted./gate on stock manifold.
cheers
darren
Please share the result once done. I am throwing around ideas for a low budget race car.
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
