Hi guys and gals,
Anyone one know how to diagnose gearbox problems out there?
My 33 GTR (only recently purchased) has a gearbox issue.
Hard to get into 1st gear.
When cold almost impossible (hard to get into any gear), so I have to "force" it into 4th gear and then I can slip it into 1st.
When at normal temp it is easy to get into any gear but a lot of the time still hard to get into 1st.
This is all while car is stationary. Once moving easy to get into all gears at all times.
So my work around is to either slip it into 1st just before cars stops moving (if I come up to a stop sign)
or if stopped at lights I slip it into 4th and then straight into 1st (goes into 1st really easy using both methods)
I have changed gearbox oil and still same
Any ideas
Do you think gearbox or clutch problem?
I have one of those cheap "purple" clutches. Heavy duty but cheap...can't think of the name at the mo.
The only thing that points me to a clutch problem is that from cold it makes a bit of a bearing noise on first take off and
you can feel a vibration thru the pedal.
Goes away after that.
Any ideas???
Please
https://www.sau.com.au/forums/topic/426164-gearbox-issues/
I'd say start with the easy stuff. You've did the fluid change, what I would also do it get some nulon gearbox additive in there two. I think two tubes suits the RB box. I'd then do the bleeding of the clutch system and if I were you, Id get a braided line from the master to the slave and bypass the crap in between. Makes bleeding alot easier and you eliminate the other unnecessary components(don't hold me to this but I believe they're not needed). After you've done all this and if everything is still the same, I'd say its out of your hands. Unless your master or slave are faulty and not throwing the clutch out far enough. My car is abit tough to get into first and reverse at times but definitely not what you are experiencing. Two things you can do, drive it until it gives up or get it pulled apart and rebuilt. I really wouldn't rebuild it, whats happening sounds like a nuisance but wouldn't be enough for me to justify a build.
https://www.sau.com.au/forums/topic/426164-gearbox-issues/#findComment-6873037
Yeah I did the nulon additive with Castrol oil. Maybe I need to go better oil but thought with the Nulon would be sufficient
Haven't tried the clutch bleed yet
I suppose that is next, as I agree with you not prepared to pull apart yet
https://www.sau.com.au/forums/topic/426164-gearbox-issues/#findComment-6873066
I recall an older oil referred to as smurfs blood because it was blue. No idea which oil that was but it was in my car prior to my first oil change. It was good shit but couldn't find it so I went with the VMX stuff from castrol and it does pretty well. The shop I get my juice from doesn't have very many options. You could go with a really premium oil and see how it goes. The Nulon additive should have helped.
https://www.sau.com.au/forums/topic/426164-gearbox-issues/#findComment-6873087
2nd that, both my R33s has VMX80 and was a little notchy, dropped in Redline Shockproof lightweight and it felt completely different.
Thanks
I might as well give it a try.....as its probably my cheapest option
Have now bled clutch and still same
Cheers
https://www.sau.com.au/forums/topic/426164-gearbox-issues/#findComment-6879185
is the clutch fully disengaging though? I had some ling long piece of shit PBR clutch in my current R33 and with the pedal down the clutch wasn't fully disengaging. It went in the bin within 2 weeks, replaced it with a NPC clutch and happy days
https://www.sau.com.au/forums/topic/426164-gearbox-issues/#findComment-6881677
Like John said, eliminate the simple items before you go down the synchro or expensive oil change road.
It really does sound like the clutch isn't disengaging properly.
This might be an adjustment issue or the spigot bearing could be dry, any workshop worth the name will soon tell you.
So don't force it into 1st, try to select reverse (gently) since it has no synchro.
If you get a consistent crunch or worse, a gear on gear grinding noise, your clutch isn't disengaging fully.
https://www.sau.com.au/forums/topic/426164-gearbox-issues/#findComment-6881931
This interests me as my car sometimes needs a couple of goes to get into reverse. It feels like its in but its not. I know my master is probably the problem but often if a problem isnt enough of a problem, im a lazy lazy man.
https://www.sau.com.au/forums/topic/426164-gearbox-issues/#findComment-6882810
Reverse gear is straight cut, not helical so its sometimes not easy to get into so you have to roll a bit to get it in the right spot.
When was your clutch last replaced? Sounds like there is not enough throw to select the gears, but once moving it helps it get into gear. I had the same problem but the sleeve my bearing slides with cracked and my thrust bearing wouldn't engage the clutch springs completely. i drove my car to the workshop with only the bearing pushing on the clutch a little. i noticed skyline gearboxes are fairly easy to get into gear will very little clutch there.
Adjust the master cylinder from behind your clutch pedal and there should be a difference.
https://www.sau.com.au/forums/topic/426164-gearbox-issues/#findComment-6885370
  • 3 weeks later...
Our track car was like that, had a twin plate in it at the time but was notchy and shitty as when cold then got better when hot. Dropped out the twin plate and put in a heavy single plate with a rebuilt box and its smooth as silk. My 33 street car (which before the track car got its overhaul felt smooth as) now feels like a piece of snot in comparison. New syncros make a hell of a difference. Both run redline oil.
https://www.sau.com.au/forums/topic/426164-gearbox-issues/#findComment-6908468
Using lightweight at the moment in both track car and street car. Have done 4 track days with rebuilt box and redline oil, no gearbox worries what so ever. Street car did pump out about 100ml from breather after an aggressive hills run, but I put that down to filling gearbox up with only the front lifted off the ground when filling. (slight angle may have overfilled).
https://www.sau.com.au/forums/topic/426164-gearbox-issues/#findComment-6909537
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
