Also removed the aeromotions computer which weighted 3kg, that is heavy. So in total another 4kg out of the car for the day. We have bets on what the car will weigh once completed, Brett and I reckon 1270kg, dean reckons 1250 and if its not he's gonna cut everything out till he's right. Next week ill start on the bonnet and chop it up.
The whole engine except for the hypertune plenum was cryogenically frozen, from the block to the clutch and flywheel, head, nuts and bolts, the lot. I have no idea if this actually prolongs the life of the parts, but went for it on the engine builders recommendations.
I have heard good things about the cryogen. I didnt think it was worth it personally, but apparently it does make a difference. Got told they put some valves in a vat and they were noticeably harder to machine afterwards.
Did you buy a unfinished camshafts and have them custom machined? how much did that work cost (minus the camshafts themselves)?
I hope so, I guess time will tell.
Nah, they are an off the shelf order. My engine builder is secret squirrel when it comes to the cams. Not sure why, they are just cams I say. But I wanted to at least show everyone the specs of em. Edited by stevena
+1 for wrapping.
You'd get wicked glare from the sun if you dont.
Wouldn't be fun half way through a turn and the reflective light from the sun blinds you!!!
Great ideas guys, I even had to look up "flocking" as I didn't know what the process was, have seen it before but didn't know what it was called. I like the dark carbon look wrap, not sure if Steve's is black or carbon black, bit hard to see with that photo but love your dash dude.
Carbon doors with plastic windows weighing 8kg, I can't decide if I should cut up the door also, I can get another 1.5-2.5kg out of them, cut or leave?
Cut em. This is balls out, every little bit counts.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
