Also removed the aeromotions computer which weighted 3kg, that is heavy. So in total another 4kg out of the car for the day. We have bets on what the car will weigh once completed, Brett and I reckon 1270kg, dean reckons 1250 and if its not he's gonna cut everything out till he's right. Next week ill start on the bonnet and chop it up.
The whole engine except for the hypertune plenum was cryogenically frozen, from the block to the clutch and flywheel, head, nuts and bolts, the lot. I have no idea if this actually prolongs the life of the parts, but went for it on the engine builders recommendations.
I have heard good things about the cryogen. I didnt think it was worth it personally, but apparently it does make a difference. Got told they put some valves in a vat and they were noticeably harder to machine afterwards.
Did you buy a unfinished camshafts and have them custom machined? how much did that work cost (minus the camshafts themselves)?
I hope so, I guess time will tell.
Nah, they are an off the shelf order. My engine builder is secret squirrel when it comes to the cams. Not sure why, they are just cams I say. But I wanted to at least show everyone the specs of em. Edited by stevena
+1 for wrapping.
You'd get wicked glare from the sun if you dont.
Wouldn't be fun half way through a turn and the reflective light from the sun blinds you!!!
Great ideas guys, I even had to look up "flocking" as I didn't know what the process was, have seen it before but didn't know what it was called. I like the dark carbon look wrap, not sure if Steve's is black or carbon black, bit hard to see with that photo but love your dash dude.
Carbon doors with plastic windows weighing 8kg, I can't decide if I should cut up the door also, I can get another 1.5-2.5kg out of them, cut or leave?
Cut em. This is balls out, every little bit counts.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
