hey mate, just want to say yours is the only red skyline Ive actually liked...so well done.. i normally don't like red on cars period :)
im running a simmilar settup to what your looking at... 720cc injectors/z32/nistune/atr43ss2 and im making 265rwkw at 18 psi but have a top end restriction so once i sort that out il be seeing closer to 300
its a great turbo man... lose a little bit of response but it kicks you in the face when it hits... as for the intake pipe i would seriously consider getting that replaced with a metal one at anything over 220kw (from past experience)
cheers man. keep working hard..
gtt master race mate! +1 sub
  • Like 1
Timmy just asked him about it!!!! He said it should be sweet. Very excited. The old wallet is taking a beating.
My next problem:
Should I install my turbo and replace exhaust gaskets and drive up to central coast from western sydney?
or should I pay to have it fit in there..
There is a big price difference. Some people say its fine. Jez is advising against it.. I am unsure what to do
Yeah I wouldnt drive it untuned... or if you have too I wouldn't hit more then 3k rpm as well as not driving very far
Have a look around for cheap tow.. or maybe even see if someone on here has a car trailer you can flick some dosh their way.
Good luck either way mate itl be fun when its in!
  • Like 1
i put a hypergear highflow on mine many years ago and drove it to the tuner.. going to central coast though you're bound to put it on some load going uphill which might be a risk
tow would be silly expensive.. If it was me 2 yrs ago I would of risked it if it was a relatively standard setup and done something like leave the actuator off so it was a pig with no power, would use a full tank driving that far easily though
  • Like 1
Maybe I'm alone in having driven with my highflow fitted for around 6 months running on a 10psi actuator - the ECU seemed to handle it fine (I did disconnect the factory boost control).
If you had a bigger actuator / higher boost, that would definitely be a problem though.
  • Like 1
Joey!!!
I wish I could as they are right behind my house. But they seem pretty busy for the time being as I haven't heard back from my enquiries yet. I decided when I go the e85 route and get an ecu I'll do it with them for the final form
Hopefully jez will help me with my daily duties for now.
Man you gotta go in and see them, they deal with bulk time wasters so at times they may be too busy to reply or call back. If you see them face to face the they know your serious. Even after all this time I always going in and have a chat to the boys if I need stuff done :)
They should still be there when you finish work and if you can't get Yavuz make sure you get a hold of Mark
  • Like 1
Yeah that's probably why I think. That's fair enough. I've only heard good things. I have been there before a while back briefly. I don't know them personally though. I've already committed to jez. So we will see how it goes.
Put a leather steering wheel cover. Turned out okay
My leather was all cracked and spliting on my standard wheel so I put a JDM S15 wheel in wiring harnes is the same as r34 so the airbag & horn plugs straight in :)
Edited by DoseVader
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
