dunno but you've got the big ass 4 door, so plenty of room in that boat to drive around the kids in the holidays
Nah during school time is better cause they all congregate in one place. nd 14 yeah old grlz luv the sutututu
Sorry OP you can have your thread back now.
Yep, I'm convinced. Obviously its a combination of a few things that make the neo head far superior, so going away from that head would be retarded!
Looking at piston choices, and comparing chamber volume of a RB30e/t to NEO it seems if I gett the RB30ET pistons with a 4.5cc dish i will end up slighlty higer than the claimed 8.5:1 , which would be spot on.
http://www.aclperformance.com.au/NissanRB30ETForgedPistons.htm
and from webbers guide
As listed in a previous section The head combustion CC's are as follow:
RB30E/T 55CC
R32 RB25DE 62CC
R33 RB25DE/T 63-64CC
R34 RB25DE/T 50-53CC
R32/R33/R34 Rb26DETT 64CC
Deck height to be machined to set compression ratio.
So my question is, have people used them? I have searched like mad and havent found concrete evidence of success, just some people that were planning on using them.
My concern is piston to valve clearance.
Any thoughts are appreciated.
Mahle Pistons Nissan RB30DET(Skyline) 86.5mm Bore NIS264405I05
available on ebay for around 800 delivered, will check local prices.
These seem to be the go. Its so good when a piston manufacturer gives the head cc's when stating comp ratio!
**edit, bit concerned by tiny skirt for daily use, don't really want loud pistons.
Edited by superben
If someone can show me a NEO head out perform a non NEO head for power and response on the same motor ill eat my shirt.
The only advantage I see with a NEO head is the ability to use bigger cams while retaining VCT, all other differences would be hard pressed to see a change on a dyno.
Use what you have and save your $$$.
have to agree, while the neo head is better, far superior is a bit steep, both motors in good condition with same mods produce a very similar result
any proof otherwise?
did hear of a neo flicking a shim out recently but didn't hear back why
    • I found a supplier for an arm in NZ. https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-rh-side?srsltid=AfmBOopMdfCFDc_8yVZZ9kq5nIngPHRTBzUU8v4SAptJaRO52Wjs0bC6 I looked closely at the photo of that one and the Z1 arm, and it's the same bloody arm. Scratches all match in the photo 😂 How hard is it to change that joint? Also they seem to be listing two options https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-balljoint-rh-side?_pos=1&_sid=229acde44&_ss=r And now I have no idea what size I'd need yay
    • Ill review it again, from memory when I first saw some of Trailer Park Boys I wasn't a huge fan. I ended up at Letter Kenny after watching Shoresy, which is a bit ass backward, ha ha
    • "lol dunno" either But like you, I can't see any reason they would need to be different LHD to RHD
    • I agree with you WRT the hard top. MX5's may be one of the better looking soft tops but I cannot think of ANY car, EVER that looks better with a soft top vs a hard top (or a designed roof). At all, ever. I also feel this way about the C5 Vette, the Z06 looks horrible compared to it's original form, it has an exaggerated version of the differences you're talking about.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
