Words cannot express how damn cool this is, how neat and tidy the craftsmanship and how fast you get it done. :O
Reach arounds speak louder than words and your pictures tell a thousand.
Does anyone else think that it would look mean as in satin black?
Some SLR5000 guards, satin black and fark off wide deep dish gold simmons F90's.
  • 3 weeks later...
Another job done, used the rear r33 tailshart and shortened it 45mm shorter than the r32 tailshaft and cleaned and regreased the cv joints.
Found the r32 cv has a rubber seal at the back and the r33 doesn't
R33 cv
Mate, your project is off its head!!! I love it!
Funny, a few years ago I bought a R32 GTR rear end to graft into my LX hatchback and everyone told me I was a fool to consider the project! I still have the rear end and the jig that I made to move the project forward and I have a few spare resto hatchbacks in my shed... maybe one day!
Inspiring stuff mate. Keep up the great work and keep the inspiration coming.
  • 3 weeks later...
WOW,
so glad i found this thread,
have you spoken to an Engineer about getting it registered?
i have a 71 LC GTR, and started putting a 3l with 26 head & single turbo in it a few years ago (on hold for now), i bought the 32 front cut, and always pondered about using the 26 sump and making a AWD torry (GTR into GTR) , but my skills are nothing in comparison.
and i was really worried about NCOP's as they where just coming out then.
keep up the awesome work
  • 4 weeks later...
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
