Looks awesome Glenn, glad to see you're getting stuck into it again!
I'll have to drop around for a look soon.
The Torana hatch is definitely a shape that can be made look very nice. Big arse flares are certainly a good start to that!
Started extending one of the front flares, thought I would try the tape and bog trick.
Cut the bottom off the flare and screwed both parts to the guard.
Put masking tape across the two.
Mixed up some bog and towelled over the tape and also cut some tig filler rod that I pushed into the bog to give it some extra support.
After the bog was dry I remover the flare and fibreglassed the inside.
Still needs a lot of work but should come up ok.
Got the other side flares done and put it on the ground to see how it looks.
This is with no springs sitting on the bump stops to check clearances.
This is at standard ride height, will probably lower it about 20mm.
  • Like 4
Decided to try and for Currie Enterprises Johnny Joints to the front caster rods since the rubbers are flogged out.
I think these will be ok considering they are used in the suspension of 3 ton rock crawlers and the engineer is happy with them because of the urethane bush.
It's a pity it wasn't 0.4mm bigger in diameter then it could have been pressed in and not have to weld it.
Tapped a new thread for the grease nipple through the castor rod and lined it up with the grease nipple hole in the johnny joint then welded it on both sides.
Also dropped the motor, turbo and dump pipe back in to see if the brake line will clear and be far enough away from the exhaust.
  • Like 4
Started filling in the gap from cutting the body to clear the tyres, because I've had to cut so high I had to weld the two inner panels together first.
The fun of welding through tar, body deadener and paint.
Little bit of rust in the lower 1/4 so easier to just cut the whole section out as this is covered by the flare.
One side done.
I always liked the drop tank style look on the old SLR5000 Toranas.
If you wanted to keep that style, maybe you could speak to Julian at Aftermarket Industries about a fuel cell setup that replicates that and incorporates baffling and a surge tank internally.
He does amazing work and comes highly recommended for all sorts of fueling work.
    • If we're going after market gauges, I'm a big fan of Australian made... Get some RedArc!
    • Unless you're fortunate enough to buy a newer car, getting an older style plate to match your name/car is difficult because they've already been purchased.  Unlike other countries, personalised plates are locked to the country and not region, so there can't be multiple versions of the same plate but with a different area code.  Hope that helps
    • People use the numbers to make it look like letters to spell words/names, which is where the illegal spacing comes in. For example this GR Yaris
    • Today's rock removal from my stock pile out the back into a 4m³ skip bin, I still have a bit to go, hopefully there's enough room in the skip bin, it will be close My daughter and her boy was coming on Sunday to help, but, I got possessed by demons and started work as soon as the bin arrived at 1230 today Lots and lots of barrow loads were achieved  Currently I'm sitting on the lounge drinking beer thinking of how I should have waited till Sunday for some help, tomorrow will be a day off, in saying this, my day off will involve prep and paint of my alloy coolant and PS tanks with wrinkle paint (Jackie is in Sydney till Sunday so the home oven will get a run curing the paint....LOL)
    • That's why I said it is a meaningless term. Because there is more than one meaning that people can apply to it. When we said "highflow", that is exactly what we mean, and exactly what is done. In a highflow, they take your housing and machine them out to take bigger wheels, have a better internal profile, etc etc, and fit a new core with the different/better/bigger wheels.
