What turbo? How much? How many kms? :) I want at least 330hp
What happens when you get 330hp? Do you go back in time or something?
Chicks see the dynosheet and throw panties at you?
What did chip torque do? Last time I went there the result was good!
I was such a noob when I bought the skyline..
Well the guy said he didn't know much about my car but I pretty much took it there after I bought it..
He couldn't tell me the chip he used...
Was very helpful with the questions I asked but not sure if I actually got the right answers.
171atw.. But he knew that I had bigger injectors (550cc) and that I wanted to put them in.. Wasn't aware I needed another tune after installing them (told you I was noob)
Got tune done then he says ill have to bring it back for ANOTHER tune, if I want to put injectors in and I was like "thanks for telling me now.."
He says its a ChipTorque chip that he used??
So not sure if its nistune? Unless he just says that because he wants me to go back to him..
Pretty sure I payed too much as well aha...
Edited by ZRBE
Have heard good things about millennium not bad readings at the same boost level I'm running.
Out of curiosity what was it like price wise ?
Price was done at an agreeable trade value. I'm not sure how many hours the average tuner charges to tune a car (assuming they're tuned from scratch) but because we did a pre-tune in house/street tune (no dyno) before handing it over to Carlos, it did make the job a lot easier/not as time consuming. best bet is to call and talk to him as I'm sure he can help with a full quote or per hr figure
Haha yeah pretty much :)
I think I'll stick with the ss1pu that someone put me on to, apparently good for 480 horses :)
Hey, I don't remember who told me to buy the ss1pu turbo but does it bolt up to standard rb25 neo manifold?
I did and yes it will bolt up to it, Explain to Stao what car you are fitting it to.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
