i have a r33 GTR and its makeing a ticking noise im pretty sure its a hydaulic ligfter ive tryed flushing engine oil, fitting new oil filter and putting lifter free in my new oil but its still a loud ticking noise any help would be appricated.
https://www.sau.com.au/forums/topic/427364-loud-noise-in-engine/
Have the exact same noise in my r32 gtst.
Ticking gets faster as you accelerate, sounds like its coming from under my cam cover...
check for loose bolts on your exhaust manifold. could also be a knackered rocker cover gasket. change it anyway its 50 bucks.
also put in a bottle of lifter free up. all that should cost you 100 bucks. if it fixes it you win. if not your looking at new lifters mate.
Edited by Plattsy
Dude RB26's dont have hydraulic lifters. But they do have very noisy injectors. And a propensity to run big end bearings.
Edited by djr81
With a wooden dowel about 40cm long place one end on different parts of the block/injectors etc and listen to amazing (or annoying) sounds!
Wood helps to localise the noise better than a long shafted screwdriver IMHO.
*The other end goes to your ear hole if I wasn't clear enough :P
Yep do this before you take it anywhere at least it will tell you whether it is top or bottom end. IMHO if it is happening when you put it under load and then gets a bit louder or changes slightly when you back off the throttle = bottom end = rebuild. But confirm it as mentioned above first. Let us know.
The noise could be a number of different things, including anything that has a pulley that the belts wrap around. Like the alternator, etc... It could be the valving as noted above, and it could even be the apex seals tapping on the housing (which is really not good). In theory, it could also be a fuel injector problem.
This is some of the dumbest advise ive ever read on SAU, seriously if you know nothing about engines or diagnosing please just keep it to yourself.
And the reason Im harsh when it comes to advise giving is because the wrong advise will always lead to worse problems and more expensive repairs...
Please, for the love of god, if you know so little about an RB engine that you think it could be apex seals in a piston engine, you need to stay the hell away from cars.
I associate ticking to a bomb ....
Ticking in mine turned out both times to be big end bearing - just sayin'
BTW: Departure posted and by the looks of it departed !
Agreed, a loud tick that increases with revs is baaaad......sometimes.......its not really a tick if it quiet then is it, more of a click bang lol
and yes lol looks like he vanished...or forgot his password so i guess we will never know
sorry guys been pretty busy its defently sounds like its comeing from the lifters as i tryed the wood theory is it verry hard to get to the lifters ?
Depends what you mean, and what you are planning to do when you find them, and find they are solid lifters.
To answer your question, it is not a big achievement to get to the lifters. Surely that is obvious!
at least she is hot!
Also,I wonder what housing the apex seal would tap on? :)
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
