Hey guys and gals,
I have made the decision to change my cams... At the moment I have hks step 2 272's with 10.2 lift. I'm changing because I want more response down low on the track instead of having to keep the revs up between 5g and 9g.
So question is what cam size would you use? The head has had extensive work done, motor is fully built running -5's, running 98 octane and it's a 2.6. So I am after something that is going to match and make the most out of the engine and turbos for track use.
I'm open to any suggestions. Cheers
https://www.sau.com.au/forums/topic/428164-what-cams-would-you-choose/
  • Replies 63
I had 260 x 260 tomei cams, had the standard cams put back in, 355 rwkw with the 5s at around 7000 rpm and the car feels great to drive.
which 260s did you have ? would be awsome if you have before and after dyno charts to see the difference between the two cams ?
B type poncams, this was a fresh build at a new workshop, I would love to know myself.
What I did have was -10s with Poncams, Motec M800 at 25psi on Shell 100 octane for a disapointing 350awkw, soon after the engine shit it self.
New setup -5s with stock cams, in went my old power FC with Nismo AFM with just over 20psi on Shell 98 for 355rwkw and so much better to drive, the engine dosn't have to run as hard to make power.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
