Sau Nsw Tech Night: Suspension & Steering @ Heasman 06/09/13
Yep! Coming mate?
List updated! Thanks Eric and Mat, no sausages for you guys, not sure if it's either good that theres more sausages for ourselves or bad that theres so many sausages already.. hmm.
yeah ill be there
^^^ I can certainly take you to Strathfield after dropping God_speed back to Earlwood first!
If someone else puts their hand up to give you a more direct route, that's OK too :)
Hey guys, sorry I know it is late and I have already confirmed but I was just told last night I have to pick up someone from the airport Friday night and therefore will not be able to come. Spewing!!! Always get told last minute :(
Sorting out SAU NSW membership now. Is it possible to be added to the list in place of someone that can no longer make it?
I dont see it being a problem unless Ricky has a list of reserves im unaware of. Best to send him a PM to make sure once you have sent off your membership
If you know how to CC people into the conversation add me in and ill followup membership status
PM sent. membership process completedat my end. Thanks
Gday Guys, My names Brad Heasman, thought id quickly introduce myself here before I meet all of you on Friday night.
I currently work in sales and marketing in our Bilstein department, but did 3 years as a mechanic in our workshop. Im 21, love nissans, and I own and race a Nissan s14 time attack car. (which you will see on Friday)
On the night we will be having a bbq, so when you arrive there will be some food and drinks here, We will have our Bilstein engineers here, our sales guys, and some of the workshop guys here for you to talk to, or ask any general questions while we eat.
We also have a few supercars in the workshop that aren't nissans :yes: but we ask that no one tries to open or get in them, the race cars on the other hand you are welcome to climb into if you feel the urge.
I will have a photographer here as well, but everyone is welcome to bring there own cameras etc.
( any questions just post them here )
Look forwed to meeting you all!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
