Hip flexors I don't find too bad as in you can give them a good stretch and they come good, the back I'd be cautious of.
Yeah I'm not sure why my left side is so sore. I assume my technique is still off as I can see I'm rounding my back. I'm going to practise with a rod tonight and make sure it's staying in contact with my head, back and tailbone as I'm pretending to deadlift. Hopefully I can fix the problem.
I'd concur with that, I used to try and use the window and it made me over extend. My session with Matt helped me get the feel for where it should be and how it will feel when the lower back is straight (the upper back can be rounded and lower back still straight, if everything is straight it puts excess stress on the lower back via leverage).
pfft. mirrors.
If this is deadlifts or squats then mirrors shouldn't be used. Looking at them while moving is contrary to what good form looks like for both.
L33SH, you should be ok without checking the back. Deads do work the lower back so occasional soreness is normal. Just check the back mobility for issues.
Edited by rev210
22/07/13
Flat Bench
25kg x 10
30kg x 10
35kg x 10
40kg x 2
42.5kg x 2
45kg x 1
Squats
30kg x 10
35kg x 10
40kg x 10
45kg x 10
45kg x 7
50kg x 2
Close Grip Lat Pulldown
30kg x 10
40kg x 10
40kg x 10
50kg x 10
55kg x 8
60kg x 2
Incline Press
20kg x 10
20kg x 10
25kg x 9
25kg x 9
30kg x 3
30kg x 3
Tricep Pushdown (double pulley)
25kg x 10
30kg x 10
35kg x 10
35kg x 10
37.5kg x 8
40kg x 4
40kg x 3
Captains Chair Leg Raises
10
10
10
10
Captains Chair Knee Raises
30
You put your right foot in, you take your right foot out, you put your right foot in and you shake it all about (you don't have to do this part, Dan).
Captains chair is a static machine where you support yourself in the air by your arms, then raise your legs up in front of you. It's sort of the opposite of a situp. Works hip flexors and abs + bit of hamstring stretch in there too, depending how far you bring the legs up.
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
