Hamstring issue really plays up on leg press, didn't hurt during squats but couldn't do my usual weights. I think it may be due to my right knee bending in when squatting and I'm causing injury. A guy said I should look at knee wraps or bands when squatting, what do you think?
great efforts Leesh. You should be able to focus on the squat technique without those things, at the rep range you are doing.
You still have a shoulder issue? Are you still doing behind the head standing press?
Okay I'll focus on keeping knees out without those. Hamstring hurt walking to work.
Yeah its getting better but not 100% Started shoulder press last night for first time in 8 weeks; changed technique though
Shoulder wise, if you have inpingement , then it's not going to be better doing bench or shoulder press. If you don't then all good but, be aware that rehab work is important. I don't see the rehab in your workout? Perhaps you are doing it but, not writing it down.
Good to hear about technique. I assume you are now doing seated press in font as opposed to standing behind the neck?
no rehab, I'm doing the program Birds just made up for me.. he didn't give me any rehab to do
No I'm not doing it infront, just not going down past the ear
Do you want some rehab movements? Can help there if you like.
Ask Birds to give you an alternative shoulder movement, seated. At least that way you can train full ROM.
yes please, that would be great thanks
Hmm, can't I just do shoulder press seated?
Sure . I will ping some info up later for you.
You can do the press seated , great idea. In front of the head is good for the pressing movement . Find a seat with a slight recline on the back support to make it straight forward.
Here are some that won't mess up your normal routines and will do wonders, injury or not. This is rehab stuff assuming we take it easy. Once there is improvement you can add something resistance wise , like cuban press.
You can youtube search these ones, to make it easy.
Total shoulder girdle health . Do these 3 times a week. Can do them at home in some cases.
1) Serratus Anterior (Activation movements) are in here for you which should help. This sucker stabilses the scapular movement,
a) Scapular pushups. Just a pushup with you extending and retracting the shoulder blades. The movement is shallow( no where near the ground , motion is small) .The arms straight. Do 3 sets of 20-25
b) Single dumbel scapular protraction. Lay on a bench. Fairly light weight dumbell in one hand straight up. Straight arm. As above move the dumbel up and down with the scapular motion. 20-25 reps as above.
c) Scapular wall slides.
d) Prone Cobras held for time.
e) External rotator bands
f) Shoulder dislocates with band or a stick ( can use a barbell if you are strong).
Try these ones for a month.
26/09/13
Squats
35kg x 10
40kg x 10
45kg x 10
50kg x 8
55kg x 3
60kg x 0
Bench Press
25kg x 10
30kg x 10
35kg x 10
40kg x 4
45kg x 0
45 Leg Press
80kg x 10
90kg x 10
100kg x 10
110kg x 10
120kg x 10
130kg x 10
140kg x 10
150kg x 6
Chin-ups
8
7
6
6
5
5
Shoulder Press
10kg x 10
10kg x 10
15kg x 10
15kg x 10
20kg x 5
20kg x 6
Seated Row
20kg x 10
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 5
55kg x 1
Hamstring Curl
20kg x 10
20kg x 10
27.5kg x 10
27.5kg x 10
30kg x 6
30kg x 6
35kg x 2
40kg x 1
Bicep Curl
15kg x 10
15kg x 10
15kg x 10
20kg x 6
20kg x 5
20kg x 3
Captains Chair Leg Raises
20
20
20
20
20
Knee Raises
20
Ab Crunches
60
Just saw this.
Either:
a) tie a theraband around your knees and force them out while squatting
OR
b) get someone to wrap a band around your leg (just above the knee) and pull it towards them, while you lunge (they should be pulling the band from the inside edge of your knee). Force your knee outwards (track knee in line with foot) so that it doesn't fall inwards.
I would recommend the latter
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
