hey Leesh do you have flat feet and or "duck feet"?
flat feet:
I couldnt find a picture of duck feet in humans but its whenn you walk, your feet point outwards.
I have both, both are being fixed but I bring it up because there are issues with my squat from them, one issue i have is knees bending inwards like you are describing
I have no idea about my feet? I might go to athletes foot and get them to use that machine on my feet.
I did 100kg last session too! However last session I only did 1 of 90 and none of 80kg. It's the other sets that have jumped up
Shall I try 105kg next session?
I'd stick with where you are now until you can manage 2 or 3 reps of 100 :) Even if it means resting for like 10 seconds between reps, just don't let go of the bar. Either way, congratulations on 100kg Lessh! It's pretty damn awesome ;)
i agree with troy.
focus on getting 100kg to 5 reps then treat yourself to a milkshake (or something else that you enjoy) as a sneaky reward
As you get stronger the sets before your heavy will increase because you aren't as tired as you are when you build up to that 100kg dead. This has been the basis of Rev's argument with Bird's about the best way to get stronger and how volume before strength isnt as productive (i guess had a mind blank for the word i was looking for) as straight out strength training.
Nothing to be upset about its natural. I say have a longer rest between your heavy sets and push that extra rep out
07/11/13
Squat
35kg x 10
40kg x 10
45kg x 10
50kg x 7
55kg x 3
40kg x 10
40kg x 10
40kg x 10
40kg x 10
40kg x 10
40kg x 10
Lat Pulldown
30kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 10
60kg x 6
Seated Row
30kg x 10
35kg x 10
40kg x 10
Ab Crunches
200
Training tonight was a waste of a time. I'm so sore the day after deadlifts I can't do shoulder press at all and lat pulldown and seated row well below par. I really don't know how to do my days. If I do Thursdays session on Friday then I'm still going to have an issue doing squats on the Saturday. I can't train the day after deadlifts so I don't know how to do it :(
Here's a scenario.
1 warmup set of a poofteenth of nothing (dynamic stretch) then 2 sets of 95kg . big fat rest in-between sets . How long? Wait till your pulse returns to resting. Whatever reps you get. Should be in the 3-5s but go to failure. No max rep stuff every workout,
Up your weight in a week by 10kg - (try 105kg for 3-5 in the first set, if under 3 reps then go 100kg for second set) do the same thing. See what happens.
And so on. reps in the 3-5's , under 3 drop weight (no loss if you do 2 still will do the job) , over 5 up weight
eg; get to 6 reps and increase kg to drop to 3 reps.
No more 1rm till christmas. See if you can unwrap 140kg as a PB.
Re: Rev's post.
Leesh he's basically saying do a few low weight warmup reps then get right into the meat of it and start pushing the weight up rather than doing eleventy billion reps at weight you have mastered at the expense of being able to push your max anywhere because you've already wasted so much power earlier in the set.
I realise this goes against Bird's volume training methodology, but you're a big girl and if you want to try something new, go ahead and do it.
I mix it up from time to time and sometimes a change is as good as a holiday.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
