I'm not happy with how I'm going in squats or my technique; so where I usually just say thanks as I did with 112.5 deadlift and 40x8 bench, I don't feel this 65kg is really an achievement. I'm having huge issues with my knee bending in and I'm not going to be happy until that's fixed.
Grats Dan
15/05/14
Deadlift
60kg x 10
80kg x 5
100kg x 1
112.5kg x 1
100kg x 1
100kg x 2
90kg x 5
Bench Press
20kg x 10
30kg x 3
40kg x 1
50kg x 1
40kg x 8
Then I did resistance band bench press @ 25kg 5x5. This is to strengthen my lift when I'm pushing the bar back up; as I'm getting it up just after bringing it down to my chest, then it's coming back down a little back towards my chest before I get it all the way up.
Bicep Curl
10kg x 10
15kg x 10
20kg x 10
20kg x 5
20kg x 5
20kg x 5
30 min HIIT
19/05/14
Squat
20kg x 10
40kg x 10
50kg x 5
60kg x 1
65kg x 2
67.5kg x 1
60kg x 5
60kg x 5
55kg x 10
Lat Pulldown
35kg x 10
40kg x 10
45kg x 10
45kg x 10
50kg x 5
50kg x 5
50kg x 5
(Different machine to usual)
Decline Ab Crunch with 10kg plate
10
10
10
10
10
10
Pull-ups
3
Edited by L33SH
22/05/14
Deadlift
60kg x 10
80kg x 5
100kg x 1
115kg x 0
110kg x 0
100kg x 2
100kg x 1
100kg x 1
Bench Press
20kg x 10
30kg x 5
40kg x 3
50kg x 0
40kg x 5
Bicep Curl
10kg x 10
15kg x 10
20kg x 10
20kg x 5
Ab work
24/05/14
Deadlift
60kg x 10
80kg x 5
90kg x 1
105kg x 1
115kg x 1
100kg x 3
Bench Press
20kg x 10
30kg x 5
40kg x 3
50kg x 1
40kg x 5
40kg x 5
Bicep Curl
10kg x 10
15kg x 10
15kg x 10
20kg x 10
20kg x 5
30 min hitt
  • Like 1
26/05/14
Squat
20kg x 10
40kg x 10
50kg x 5
60kg x 1
65kg x 1
70kg x 0
67.5kg x 0
65kg x 0
62.5kg x 2
55kg x 6
50kg x 15
40kg x 40
Lat Pulldown
40kg x 10
45kg x 10
50kg x 5
50kg x 5
55kg x 2
55kg x 1
Decline Ab Crunch 10kg Plate
10
10
10
10
10
10
One is a weakness at a certain point in the range of motion, muscle related, the other is a fault in your technique...though the latter can lead to former and vice versa.
30/5/14
Squat
20kg x 10
40kg x 10
50kg x 5
60kg x 2
70kg x 1
65kg x 3
60kg x 5
55kg x 10
50kg x 10
Lat Pulldown
40kg x 10
45kg x 10
50kg x 5
50kg x 5
55kg x 2
55kg x 2
Decline Ab Crunch 10kg plate
10
10
10
10
10
10
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
