Cage looks great mate,,,now the crappy jobs start.
Some poor bastard now has to sand every tube properly,,,prime them and then final coat them in your prefered colour. I subleted that shit job out to my favorite spray shop,,,he now hates me. I have some great looking tubes but some have dry coats which look bad. No way can you perfectly paint all the tubes to a price.
The real pain in the bum is some poor bastard (probably you) has to get under the car and wire brush all those floor cage welds and seal them or Mr rust will take over.
Cheers
Neil.
Funnily enough, yes it's a bastard of a job. We've used a wire brush drill bit and without that it would have been a nightmare.
I spent a day sanding the front half of the cage and painting it. The old man then finished off the rest.
So there are two coats of grey RustSeal over the whole lot now. RustSeal doesn't have any UV protection, so we either need to clear it, or what the old man wants to
do, get some KR4 made up with UV protection and do the cage and the gruby interior.
I think I prefer the RustSeal grey, it's much lighter than Nissan KR4. But I kinda like it.
Either way it's still not over yet, as under the car needs to be done.
Found this magic paint, RustSeal that you bush on. So no need to mask the whole car up etc etc.
Need more Power ? :rolleyes:
:yes:
You know what it's like, same old story of money. Going external gate, changing the manifold is a big time and money investment.
Unless you have a spare brae manifold I could borrow for a few months :closedeyes:
  • Like 1
:yes:
Get abe to modify your stock manifold to run external hate like he done to mine. Cost me around $500 including turbosmart wastegate.post-84279-14274102715192_thumb.jpg
Probably, doesn't make that much power.
The last test it made 292rwkws on 18psi after cooler but showning holding perfect flat on 25psi precooler, That should make towards 350rwkws on pump once a proper cooler is installed.
Yep, I'm following that development at the moment. From memory I'm making 18psi @ ~3400rpm on the current turbo, so extremely responsive.
Maybe we should take the R34 out to Sandown on the 4th of April and do some track testing ;)
I'm running a Greddy LS cooler, seems ok...
Regarding ride-height..
Your car appears to ride significantly lower than the typical 350/340mm axle->arch measurement recommended by numerous people on this forum. At a guess I'd say it's closer to 330mm front and rear?
Based on your experience, how have these geometry changes (lower roll centre) affected handling?
I found at those heights I couldn't get the camber I wanted on the front. That too me is more important than bump and roll.
It sits from 325-335 depending on the track and conditions on the day. Starting point is 5mm front to rear difference though.
It has some bump tie rods in the front, though I couldn't feel the difference.
  • Like 2
Cage is all painted, might need a bit of a tidy up before WTAC so it looks pretty.
Dash is back in, with the cluster. Cleaned up a bit of ugly stereo, turbo timer, alarm system wiring while I was at it. Though the boost controller and shift light still need to be wired back in.
Screen goes back in it today.
  • Like 3
So after the fun day at Sandown there was a list of things to check off, to get the car back performing it's best.
1. check swaybar location
2. fix floor surface under the pedals
3. install roll cage padding
4. diff and gearbox breathers
5. front left steering movement
6. front splitter mounting points
7. fit new harness
So in went the new harness to make the HANS more comfortable.
Added another items to the list, that is give the inside a good clean with de-greaser
The movement in the front left was a loose bolt, with that nipped up movement was gone.
Also backed the swaybar off a hole. See if the front of the car is any different next time.
Added tanks for the diff and gearbox
We've been talking about bonnets for a while and trying to find a cost effective unit off the shelf that is aero and heat effective.
Failing to find one, we dropped two new wheels on the angle grinder and went to it.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
