  • Replies 48
Do still have these parts?
2door power window motor
ignition barrel plastic ring
indicator stalk or turn/bright switch
power window switch Left
quarter glass, with intact rubber molding
Don't suppose you'd happen to have a standard battery brace? the one that bolts to the rad support?
Hit me up on 0419170619 if you do. happy to pay postage.
  • 3 weeks later...
R32 parts for sale plus a few other bits
R33 rotors. Calipers.hand brake cables and drum assembly with knuckle $130-
Under dash panel driver side with fuse box cover $20
Stock r32 side mount intercooler $50
A pillar trims $30 each or $50 for a pair
GTST air con condenser $70
2 x r32 hand brake and cable $70 each
GTR front strut brace $100
1 x pairs of r32 5 stud front hubs and up rights $100 a pair
4x lower quarter trims $30 each
Rubber gear box surround with metal ring $20
2xglove boxes
Under dash trim panel $15
R32 glove box $30
3 x speedo clusters 2 x grey, 1 x blue dials $80 each
2 x climate control unit $70 each
Centre console dash panel radio surround $40
Upper rear trim driver side all clips still there cracked in corner otherwise good con $40
Rear bar $50
Rear reo $70
Tail lights no covers $40 each
Steering Colum surround $50
Rear parcel shelf $40
Centre console ash tray $10
Window black box driver $50
Front bonnet latch and support $50
2xwiper motors $40 each
RB20 speedo cable $70
Nissan din pocket $20
Washer bottles rad overflow and washer $40 each
Non projector headlights $200
1 x passenger window switch $50
Air con box $50
Heater box $50
Passenger window reg $70
Passenger and driver kick panel $20 each
Boost sender/sensor R32 $20
Clutch pedal $70
Break pedal $30
Carbon canister $20
Boot lid $70
Bonnet latch and cable $40
Fuel/boot cable $50
1 x stock r32 steering wheels ok condition $50
Surround ash tray $10
Front LCAs $120 a pair
Fuel pump $40
Dash all good vents small bubble on front $150
Door shells $100
2xcluster surrounds $20 with some cuts in them
Light switches/wiper switches $30 each
Carpet $100
Gear boot $10
Hand brake boot $10
Driver side dash vent $40
Sun visors $10 each
Rear view mirrors $20 each
Clutch master $30
Gear boot plastic surround $30
Indicators with wiring no outer covers $10
Wiper arms $10
Driver dash vent $40
Stereo brackets $20
2x driver side window switches $70 each
16” rays 2/3 piece $200 with good tires
Are the clusters from a gtr? Chasing one for my rb s13 conversion. Prefer grey with the needle stop at 9 o'clock. Pm me or text 0419 856 391
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
