Ok first post so i'll make this quick,
When welding or grub screwing the vct oil feed shut on the R33 head and making up an external oil feed for the vct, can i use an rb30 headgasket and put it together using the rb25 head bolts?
Then put it all back together then good to go?
My reason for asking is because in this guide he shows in the second or third photo a bit that has been welded on for seating the rb25 head gasket?
http://homepages.vodafone.co.nz/~lakewood/Skyline/R33_head.htm
Is there any benefits using the 25 gasket?
Also with running the motor in, is it best to drive it softly for 1000ks (or whatever is recommended) with mineral oil then dyno tune it or tow it and chuck it straight on the dyno?
If driving it for 1000ks i will be using all the stock bolt ons rather than the upgraded items
I am using an RB25 head gasket. Run it in on the dyno - no softly softly stuff (assuming tuner will not thrash it to death). Then dump oil and refill and drive normally watching oil pressure and temps and checking for leaks.
did you weld the block for more sealing surface in that coolant gallery or is it not as bad as it looks in that photo?
In regards to the break in procedure I've always believed in this guys procedure-
http://www.mototuneusa.com/break_in_secrets.htm
Makes a lot of sense to do it that way. Seems a little heavy handed but he's done a lot of research to show that it works.
Yep. Start, check for leaks. None? Sweet! Get on the dyno and load it up. Gave it back to me and went belting through the hills. 3rd and 4th gear pulls up hills to 6500 rpm. 3 days later at the last years nationals, Wakefield park and airport runs.
Basically gave it as much load as I could give it from as early as possible.
Last engine was run in very similar. Never breathed a drop of oil.
Running in as per Piggaz's post above has been the correct procedure for at least the last 30 - 40 years (on dyno or road) - anyone telling you to take it "softly" is way out of touch.
Anyone ever done this ^
Im going to be running one in soon the old 1000ks softly way but that kinda looks to me like i better have a spare 30 block just incase haha
go for an internal vct feed and use NEW rb25head bolts
I've heard mixed things about this method, mainly that it has the possibility of starving other components when the pressure is required for VCT? It sure would be a tidier method, anyone with experience on this have some input?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
