which wire in the ecu do u planning on hooking it up ?
i made a little switch for someone ages ago.. it had a led on it that used to flash when it was on etc.... there was 3 pins..
1 went to the power source, 1 to the ground and other one to the power source (white wire i believe) on the solenoid (not the ground wire like normal.. but we did permanantly ground the ground wire..)
if that helps at all
Well I just did mine last night and it works a treat. I actually got the switch upside down but I don't care. Mounted the switch on the dash behind the wiper wand and put the ground wire on the transmission bolt rather than in the engine bay. Shaweet!!!!!!
did u end up hooking it up to a wire on the ecu ??
not trying to be a smart ass :( im just curious as to which wire it goes to on the ecu ??
Yes. I did it as per my previous post
ya but which wire on the ecu did u hook it upto ???
All I did was snip the black wire which runs from the ECU to the actuator. I didn't touch the white (power) wire, and put a switch to connect the black wire back up. I didn't touch the power wire as I didn't use an illuminated switch.
My setup is abit different from everyone else's. Is it still ok to do this mod since the 2nd solenoid nipple is being used?
And if so, which wire goes to ground, white or black?
Your setup is the way it should be Wink, the way it was when your car left the factory. All the pictures on this thread except this one are horrible mutations (like mine :)).
hey sorry if this is a bit off topic but does anyone know where the return air tubing on the solenoid goes to? i know it goes back to the intake somewhere but i cant find the exact spot. my solenoid has been removed and i wanna check if the hole has been plugged up properly.
Pics would be muchly appreciated.
Thanks!
this could be the most stupid question on this thread, but -
if i were to pick up one of these boost controllers and a guage, could i replace the standard solenoid with it? im an ex XF falcon man - this sh*t is space age to me, and i respect those of you who understand it and pass on your knowledge and tricks!
if it is possible to substitute the solenoid with a boost controller, what happens with the pos and neg wires from the ecu?
Sorry about the late reply.
Yes, you substitute the solenoid with the boost controller...as the solenoid essentially does the same thing just that instead of allowing more boost it actually limits your boost.
You need to install the bleeder on the pipe going between your intake pipe (after turbo) and your wastegate actuator:
http://image-cache.skylinesaustralia.com/f...-1130177360.jpg
Its the pipe with the white joiner bit in the middle. By looking at your boost controller I would assume you would first plug the line into the nipple marked with the arrow, then plug the other end into the remaining nipple but if that doesnt work, try the other way around. Shouldnt matter anyway.
Hope it helps
hey guys, i just got myself a turbotech boost tap, can you help me install it, this pic, which is someone elses is clear enough to show me which hoses connects up etc....basically can you use microsoft-paint or sumthin to show me which end of my boost tap goes to which part on the intake/solenoid....hope thats easy to understand, even just labelling which hose is will help out, (ie wastgate actuator hose)
i'm really new to all this but would like to do this myself
thanks
p.s do i need to return this high boost mod to factory before installing the boost tap?as i heard this mod limits the boost from going over factory levels?
Edited by nsta
can any tell me which pin the black wire goes to on the ecu? Just so that i can do the whole mod from inside the car?
& why can't i just connect the 2 pipes up that go to the solenoid to get the same effect?
Q..and is this trick worth while doing if you have a boost tap?
A>.if you already have a mbc, this wont do anthing for you as you have already replaced the boost solenoid with the mbc
Lee
Edited by STAGE-A
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
