I have a few parts left over from my parting out my car. All parts are 40 minutes south of Melbourne. Everything came off a running car.
$3000 RB26DETT engine which I only put 10,000kms of in the whole time I owned my car. It has only been run at 280rwkw on standard injectors. Made 300rwkw on the dyno at 100% duty cycle but I wanted to keep a safety margin. I imported it with N1 pistons which has been confirmed after I removed the sump recently. All bores look good. It alway had good oil pressure. I have attached pictures confirming the N1 pistons. I couldn't tell you which model crank or oil pump. It was an extremely smooth engine. I have the turbo manifolds, dumps and new gaskets in a box. Comes with everything pictured. Also comes with coil pack cover. Sump was cleaned while it was removed. Custom fan. I never had any overheating issues and increases power.
May sell the rocker/coil pack and cam cover, sump, coil packs $450, complete inlet and everything attached to it ?? seperately if the engine doens't sell as a complete unit soon. I know most people will only be buying it to replace a blown engine anyway hence already have all of these parts.
$1500 OS GIken full face solid centre triple plate clutch. 80-90% meat on clutch packs and no hot spots on the drive plates. It is very drivable as I've driven on it in city traffic etc. These are rated to 1000hp. One of the try perfomance clutches out there today. Worth $3000 new.
$650 324mm brake upgrade. UAS adapters. Braided lines with metal fittings. New slotted rotors front and rear. Reconditioned and painted calipers. Castor rod deflectors and if I can find it a master cylinder stopper. Also have several sets of 50% worn pads. DS2500, DS3000, EBC etc.
$175 R32 GTR airbox
$100 R32 radiator
$100 resistor pack for injectors
$100 R32 GTR alternator
$100 RB series starter motor
$100 R32 GTR engine loom to ECU
  • Replies 41
Front pipe is custom made to suit the custom made front pipes $150. 3inch dump/fronts into 3.5 Y pipe stepped down to a 3 inch aft flange. Might be sold though. In corresondance with another person via PM atm.
$150 for the cat back. Sick of stepping over this in my shed for the last 6 month!
The 324mm rotors are useless to me if I sell the spacers. Only going to sell them as a kit. Really surprised the lot hasn't sold as most guys on here would pay more than the whole package just to have a pair of disks fitted.
Blitz-26 Not seperating because I don't want to be left with random parts. I know the kit will sell complete.
srig0000 I'm more than happy to send the parts interstate. Just let me know asap as I fly out with work for over a month on Thursday.
  • 3 weeks later...
  • 1 month later...
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
