Hi there,
as my r34 25det neo spun a bearing last week, I am going to be building a 25/30.
I will be using the following parts in my build,
JE pistons 86.5mm
Spool RB30det rods
ACL race series bearings
Crank collar for oil pump drive
Nitto Headgasket
Supertech valves, guides, retainers, springs
Camtech 272' cams
Bosch 1000cc injectors
Garrett GT35r .82 rear
6Boost exhaust manifold
Slide Industries Intake plenum
I'm hoping for a reliable power output of around 500-550rwhp.
I am still searching for information on how people have disabled VCT, is it as simple as welding up the hole?
so if anyone has any information please share :)
Thanks
Corey
https://www.sau.com.au/forums/topic/429221-rb30det-build/
With the cams I'll be running I wont be able to run VCT anyway, as for the oil pump ill probably end up with a new standard rb25 pump with a billet gearset :)
thanks guys
Why not change the cams then, if you are only running a GT35R surely tomei type b 260s would be a good match and you can keep the VCT. I am looking into doing something similar. A few people on here seem to be getting great results from the HTA range of turbos in terms of better response and top end power compared to the standard garretts.
My RB25 Neo is running fine at the moment and I am looking at getting one of the HTA GT35Rs and putting that on and then later down the track building up an RB30 bottom end as the 35R might be a bit laggy on the standard 2.5, even being the HTA version. But from what I read the VCT is a good thing so just something to keep in mind, a lot of the guys in the RB30 conversion thread try to keep the VCT.
https://www.sau.com.au/forums/topic/429221-rb30det-build/#findComment-6961931
That's exactly the same spec's as my motor
Accept mine has a standard bottom end & made 380kw at 17psi on 98octane.
keep in mind i had 3 broken ring lands at the time so loosing compression in those cylinders.
you should be able to crack way over 400kw easily.
https://www.sau.com.au/forums/topic/429221-rb30det-build/#findComment-6965323
okay guys, well I have received my block and head back from the machinist, I have restricted both oil feeds in the block to 1.5mm feeds, the head has been ported and had a service with the new valves, springs, retainers, and cams. the block was bored to 86.5mm and drilled and tapped for the extra tensioner as well as a crank collar fitted.
I'll add some pics in the next few days :)
https://www.sau.com.au/forums/topic/429221-rb30det-build/#findComment-6976704
Hi there, it will be used as my daily with the occasional track events, as for engine builders I'm not exactly sure where your from, RIPS always seem to build some porn looking motors but I've gone with a local engine builder so I'm not really familiar with who else is out there, usually a machinist shop is a good place to ask or your local import specialist will have a good idea
https://www.sau.com.au/forums/topic/429221-rb30det-build/#findComment-6990751
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
