With faux RAF stickers? Time to pick up some MG 17 cannons from a ME 109, to put real bullet holes in it.
nah personally would get the gulf racing one.
I keep looking at it but yeah looks like going to be 70K plus and that way too much for a toy..
does any one know if its going to be an issue if my partner adn i go from entering one car each to sharing one car?
her car has decided it doesnt want to play fair any more.
Not a problem, just write on the second entry form that she's "double entering" the car with you, then when they're working out groupings you'll be sure to be put in the same group and spaced far enough apart that the car won't die :)
Obviously you're still entering two people, so two entry forms and payments will be required :)
Bout time Jack!
Ha ha. Yep! Long time coming.
Having a baby and doing an engine will delay things a bit....
Now to finish the oil cooler plumbing and do some testing before DECA. otherwise I'll be using the wife's mx5.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
