Car Sharply Turns Left On Left Turns
wiix
 Share
Hi my skyline has recently been sharply going into left corners iv checked tyre pressures and got wheel alignment check that all checked out fine so what could it be it has new tie rods and rack bushes so it cant be those could it be any thing else ?
today while driving it was wandering on the road left and back to centers for how far i move the wheel only about 3 degrees or so and it darts it is dangerous to drive
no never had a issue from swapping from car to car
it was ok untill i took it to someone to do some electrical work then was all over the joint from then tomorrow im going to look over the suspension iv got some knowledge on that stuff as im am a apprentice mechanic
iv been doing research on other forums and the thing that describes this problem the best is a tramlining issue apparently a issue with the caster
You say it has new tierods. Was it doing this before they were fitted? Reason I ask is I had a similar, though intermittent , problem.
On left turns, the car would suddenly flick further left, like the back end suddenly stepping out. I thought it was the HICAS going nuts. Finally tracked it down to the nut on the front right tierod had lost the split pin and the retaining nut had undone itself about 1cm. So, the ball joint was slowly moving upwards until a left turn when it would pop back into position. I was getting sudden dynamic alignment changes as the right corner was loaded up.
today i was looking for loose parts i found 2 both the lower ball joints the nuts had come loose and were resting on the split pins so i tightened them up and used new split pins took it for a drive all is good now
 Share
    • Took a little trip  went to nismo hoping the get my fuel tank hoses and unfortunately they told me they didn’t have stock luckily I was able to go to a Nissan parts store and they were able to order them in for me  then can home and cleaned the tank with some degreaser and fitted the new hoses before putting it back in the car
    • 100% I’ll hack into the 33. Strap a turbo onto the RB25DE and/or put the 25 head on a 30 block. 33 passed in cos the reserve was too high. I’ll try lowballing it again and negotiate. Aim is to have it landed and on the road for under 15k, then spend the same amount on top in mods.
    • It's generally best practise to run 1x run without VCT enabled, then 1x run enabled till redline. Overlay the two torque graphs and you'll find the desired RPM to turn off VCT. Sometimes, it might be even worthwhile turning off VCT earlier control torque/cylinder pressure and using VCT purely to spool the turbo.
    • They sell them in Malaysia for about $4
    • First time I ever have issues with Amazon, but my wife often tells me to keep an eye out for fakes. It finally got me. I wrapped up the conversation with Gates. The gentlemen I was talking to seemed to hate his job but the response time on their technical support is outstanding. He stated that the hose is marked with some variation of "SAE J30R10" but that if you only purchase a 1 foot length like I did, it is possible to get a cut between markings and have a blank hose. To no ones surprise, he stated the swelling and "gummyness" isn't normal and to replace/buy from somewhere else (He mentioned NAPA). I'll toss a small end of the new one in gas for a few days before pulling the hanger out again, just to be safe.  Hose should arrive Monday. For those running multiple pump in tank hangers, you know the joys of getting them out and back in. I'm surprised I haven't destroyed my level float yet.  Lastly once I wrap all of this up, I'm planning on hitting the dyno again in 2 weeks while I'm on vacation. I realized recently that my VCT is set to turn off at 5000RPM. I'm surprised it wasn't increased while I was on the dyno last. I'm expecting I can increase it to ~6500RPM, if not more. Should hopefully get another 15-20kw out of it. I also want him to revisit my knock thresholds. I'm occasionally getting false knock around 3000rpm.
