I ran a stock internal to 450rwhp for years.  Tracked it, hillclimbed it, drove it on the road. It was fine.  Then I had it rebuilt and it all turned to custard.
If you can live with it off the road for 6 months then just use it up with the stock internals.
20 years of unknown history running at 10psi, boost it to 22psi....you better be ready.....it's a gamble doesn't matter which way you look at it. As long as the OP is aware that you are increasing the risk of something going wrong. And it is far cheaper than what you are suggesting and having an engine fail and paying for labour and turbos again.
  • 4 months later...
Couple of quick pictures
Plasti-dipped front bumper.
List of stuff had done by Josh last time:
Bcbr coilovers fitted
Work Meister s1r 28x10 +12 fitted
Archilles 123s 265x35x18
Blitz front pipes
Front and rear camber arms
Rear castor arms
Replaced busted CV
Serviced all the usual suspects
Twin plate coppermix fitted
High flow panel filter
The difference in response the clutch and flywheel is insane feels like a more powerful different car even with no power mods as yet.
Next up is:
Front r34 brembos
Rear castor arms
Braided lines
New pads
Rear sway bar
Front and rear strut braces
With the handling all taken care of I'll start building towards my power figure.
Would like to take this opportunity to thank and recommend josh and the team at galvsport I couldn't be happier.
  • 5 months later...
Next up is:
Front r34 brembos
Look at the Alpha Omega EVO brembo brake upgrade with 350mm discs, the bolts for the 34 brembos are 14mm against 12mm for the 32 ones so they don't just bolt on
^^ This!
If you want Brembo's, get a set of R32 GTR V-Spec / V-Spec II or R33 GTR calipers as they will be a straight fit and bolt on.
You will have to custom make, the R34 GTR Brembo's fit.
The GTR Brembo's are good for street and light / occasional track work but if you want to seriously track your car, look into a set of aftermarket race caliper setup.
Copy Paste from another forum.
Right here is the full list of work done this round anyway,
Engine :
Garrett 9-s
Mines Ceramic Coated Dump Pipes
Vipec V88 ecu
Blitz radiator
HKS cam gears
Tomei Type B 260/260 9.15 pon cams
DW1200 injectors
Splitfire Coilpacks
Walbro 465 E85 pump
Rips Sump Kit
Oil pump Billet gears sourced locally
ATI 1000hp harmonic balancer
Major service
Misc:
Project MU pads up front
Valley and Cam covers painted wrinkle black
Plenum soda blasted
New R34 valley emblem
Cusco brake cylinder brace
Removed clutch vacuum assist lines
Lifted car 20-30mm
New heater hoses/gaskets bolts and various other parts you would expect
Run new wiring relay to pump as stock had a current drop
Thats all the major stuff, the budget was added to significantly as decided to take the advice of josh and many of you guys here in regards to tackling the oiling issues early, sump, pump gears and harmonic balancer were extras that required engine out, it worked out fine in the end since reduced a little labour in other areas and gave me the chance to soda blast the horrible flaky intake plenum paint and paint the valley/cam covers.
Only spoke briefly to the tuner (Sean at ASG) but was as you would expect, made 470hp and turbos ran out of breath in top end which suits me fine when the original build brief was formed. Aimed for response and midrange, from the look of the graph and the very short spin I took in it today its within those parameters.
Still cruises around in traffic perfectly happily off boost and clutch feel is only slightly heavier so still very easy to daily drive. I am in love with the new idle/exhaust note though, good amount of volume without being ridiculous.
Will post the Dyno results when I get them and after have a debrief with Josh as to how it all went as he was busy today when I took it for a quick test.
Plans for future are for one to enjoy it and get it onto some track days to stretch its legs and learn to drive it but the main priority is to get the exterior to immaculate, so ill find some nismo rear pods, fix a few tiny dents and do a few small things.
Still smiling ear to ear haha
  • Like 1
Here's the dyno.
Full boost a little later than had hoped but tuner did say could move curve a bit so somewhere down the line may look at trying to get 18psi by 4k.
Stoked with power figure though.
Edited by Ambi3nce
  • 5 months later...
Quick update, went in for retune to swing cams to bring boost on earlier.
Dialed in 20psi over previous 18psi. Gained 2HP, 30+nm torque and boost is on almost 700rpm earlier. Very happy with how it is now, I would not have though that 500-700rpm in boost earlier would make such a difference, but it feels night and day.
Also got launch control set up for vipec so I can not fail miserably at the drags when I eventually get down,
IMG_20141128_201521_zpsk4ib5kz_edit_1417
Nice and strong. Must be nice to drive on the street and should be a blast on the track. Good stuff mate.
Yeah the retune made a huge difference, I did not think 700rpm would feel so different but it so much better on the street, havn't had a chance to track it yet. Blew a cooler pipe today for first time so may have to start swapping out some old pipes for newer ones/clamps.
Neat and tidy build congrats and enjoy.
Thanks man, that is the plan. Next break from work will get some small tidy up jobs done, tints to try protect the interior from the ridiculous heat here and getting some small dents removed.
700 rpm is night and day. 200 rpm is heaps!!!
Area under the curve just makes the car so much nicer to drive!
Nice build thread mate. Car looks clean, the wheels suit perfect! Awesome power delviery too.
What's the next plans for the car?
Thanks man,
Next is a few small things, tint, few small dents removed, basically get it as good as I can short of a respray.
Need to buy and install a defi 3 gauge cluster as I want oil/coolant temp and boost pressure which exceeds stock gauge.
Also will be replacing the Gsensor with a digital unit as mine is starting to read a bit off and is throwing the torque to the front at strange times.
Yeah Its so much more fun to drive now, feels alot quicker too
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
