Hi, Just a question regarding tuning.
RB20DET specialists only no RB25/RB26 replies please
I want to try 800kw on my rb20det I know it sounds stupid but, has anyone tried this before?
I know it needs a lot of mods but, has anyone achieved this before??
Please no reactions similar like these:
RB25 and/or RB26 is better.
Why not swap the RB20DET for a RB25/RB26.
RB25/RB26 is better at this power level
Why not buy a R32 GTR
It would not be economically
Many thanks
Edited by JDM_R32_R35
Doubt anyone has tried.
No going to be bothered searching if anyone has.
But you'll require 10,000+ rpm
Something upwards of 50psi
And a lot of strengthening, and flowing of all components.
And it would be a complete dog to drive anywhere except down a 1/4 mile
But for those 10 seconds or less....................................................... OP will be freeeeeeeeeeeee!
  • Like 1
Ummmmmm...... wheres Roy?
The mad scientists is probably ripping apart the block, replacing the piston rings he fried :action-smiley-069:
ha yeah if roy can't back you up you're boned
you'll need a strong laptop too, one that can handle being slammed shut & told to shut up
Dont forget to weld in the floorpan!
It can be done, it just depends on how much of the RB20 you want use
If want want the use 20 piston rods crank block and head then no your shit outta luck
But if your happy to swap them for say 30 block crank pistons and rods and a 26 head then yeah 1100 hp from a RB20 is easy done
OP, have you considered swapping to an RB25/RB26?
These are better.
Why not swap to an RB25/RB26?
RB25/RB26 would be better at these power levels. I think you should do it. I hope I was able to suggest this to you before you went ahead with the RB20, because RB25/RB26 are better. At these power levels.
Or buy an R32 GTR.
Edited by Hanaldo
In all seriousness we are talking 1000hp... I believe that to be a power figure that requires an experienced engine builder to produce an engine. That being said I also do not think it matters what modern engine you start with... To get it to 1000hp would probably be a similar amount of work regardless.
Therefore OP should take his RB20 to an experienced engine builder and ask them to produce a 1000hp engine capable of over 10,000rpm. Then OP will simply need the manifolds and a turbo to suit.
$100,000.00 later and it will rip good skids.
  • Like 1
This must be with the Motec system and a stand alone fuel management system?
  • Like 1
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
