hey all, trying to install my fmic.
I have ONE nut left to take off, to take the reo off. It's the one that you don't need to completely loosen because it's a slide one, and it's on the drivers side.
I've spammed with wd40 and been trying for the past 30mins >.<'
bloody frustrating and i need to get it off, cos i need to leave the house in a few hours for uni lol. Anyone know of any way to loosen it up easy??
My socket won't fully reach the nut because of the protruding threads. when i chuck on my extension on the socket, it's even worse cos the extension piece goes into the socket piece more.
https://www.sau.com.au/forums/topic/430218-reo-nut-wont-budge-grrr/
if the nut is frozen with rust then wd40 wont always get it off, IF YOU CAN then gently heat the nut up with a small gas torch until the nut glows red,then it should be able to be undone
obviously check there is nothing flammable in the area
Could try heating the nut up with a butane torch if you have one.. failing that I think ya should get a deep socket or else you risk rounding the nut, then you could be really stuck - they are only about $6 or so from supercheap + a $15 cheap breaker bar, or stick a pipe over your ratchet handle to get more leverage
Buy a 6 point deep socket and use a breaker bar
Yep.
Single hex deep socket.
Make sure you have it on DEAD STRAIGHT and use your wank arm with plenty of leverage to crack it off.
haha thanks all.
The head got stripped and i was stuck. the other side came off heaps easier with just a normal socket. the reo was literally hanging on that 1 bolt.
My mate came over with a breaker bar and deep socket, but it was too late..
SO, did some very dangerous angle grinding lol...
anyways, all fitted now with a lot of blood spilled and cursing to the days!!
john, no way i couldve drivven anywhere. no intercooler and car was in pieces! haha
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
