Hey guys :action-smiley-069:, after seeing all these EPA blitzes around Melbourne I think it's time I take the cannon off as it's just far too loud. I have another cat-back sitting in the shed but the problem is that though it's all nice and stock, the tip is one of those pea-shooter types so it looks sooo crap. So, I was wondering whether it's possible to cut a section where the tip is and weld on a chrome twin tip? If so, would anyone be able to help me out or know someone reliable who could do the job? I'm in the south-east suburbs (Rowville) and am willing to pay!
Cheers! :cheers:
Abz
https://www.sau.com.au/forums/topic/430647-need-some-help-please/
The only issue with old stainless systems is they need to be cleaned very well internally before welding, as carbon will contaminate the weld. Mild systems are even worse as you have rust to deal with.
For a cheap job any exhaust joint can mig a tip on it for you, if you have any issues finding someone reliable though, or you want a better quality job you can try dropping me a PM to see if i'm free sometime...
this man. he is the shit. ^ pm him now.
PM'd :D
yeah meng I had that same set up as you, just kept a epa friendly pea shooter in the shed (looked so crap) but my cannon (kakimoto racing zorst) was just far too loud at 112db. :( this one looks clean and sounds good too and doesn't hurt my ears. ^^
Glad you're happy Abz, I was actually surprised how quiet the system ended up being, for two straight 3 inch mufflers. That should keep you out of trouble with the epa, if the rumors are true they will be cracking down in December with mobile detection setups. :unsure:
Got my zorst done. :D Many thanks again to #scotty nm35 great quality work! Oh and that NM35 is a bloody rocket, my head's still spinning :P
I just found out that this is my old muffler! Lol good to see it being put to good use
Cheers mate :) so much better now and i'm getting a good RB noise :D but nothing compared to the experience of your stag :P
haha i bet your old one must have been droney as fuark then! i know my old one was... i dunno how i lived with it for as long as i did :P
new exhaust looks good :)
Thanks man! :) yeah it was drony as fuark, I took it to reefton a couple of weeks ago with some rx8's apparantly it spat flames a few times at high revs :O but yeah took two days to get rid of the drone headache. :/
Haha thanks for the muffler :P Which car did you have it on?
on my 200sx. lol it sounded nice - cleaned up the tractor sound nicely lol. scott was getting angry at me that i left it there lol so thanks for taking it lol
Haha nice, certainly sounds good on the dirty4 too and lol you're very welcome :P
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
