  • Replies 96
Any workshop that has a Z tune is serious about Skylines; publishes all their tuning figures online; holds Skyline's Australia nights and is willing to back themselves and tune a Lamborghini Gallardo custom twin turbo set up (pretty confident tuner). Very confident that Adam at JEM knows his stuff.
so, by your summary, every other workshop isnt serious about skylines because they dint have a z tune?
considering there were 20 z tunes released, I dont see how all the serious skyline tuners could own one.
I don't know how you came to that conclusion at all lol.
Ummm... "unique" take on one part of what I said. I thought we were talking about the better tuner and the reasoning to this little portion of my entire comment is that they are passionate about Skylines. In fact, passionate enough to source a bona fide Z tune, which is "one of the most" serious skylines out there. My experience... passion drives performance. Put as a simple analogy, would you hire someone that turned up to a job interview in a flannelette shirt (Don't answer it's rhetorical)
Edited by TREGTR
envy did it last tune
For what it's worth that figure with those turbos... the poor little things would have been choking for air. I had my R33 Gtr tuned there back in Brookvale days - boosted hard but the oil pressure light kept coming on and I had to back out. That was -5s 320kw. What boost did they get the 460kw figure at and was the knock sensor and oil pressure sender still attached?
Edited by TREGTR
Good choice. Technically not an argument when only one side though.
i think the next tune going to b jez but he is so far for me whats the address to this guys shop and number
I have no affiliation with either? Once you go to both, you'll be able to tell us which is "best" in your opinion.
Edited by TREGTR
Most definately can be achieved. Not easy though. Not sure what the oil pressure sender has to do with a good -5 result. :/
Interested to see a dyno sheet. No sender no oil pressure, usually follows no knock sensor Edited by TREGTR
Why so much doubt? There have been a few results that have done those numbers on -5's.
Hey mate my old dyno sheet is up in rb26 dyno results
My post numbers are pretty low and I haven't quite figured out how to access this info. Are you able to help me out with where to find it?
I recommended JEM, perhaps, in retrospect, I should have just put: JEM +1 without any reasons or ellaboration as to why I would recommend them to help you out. If you look back over other comments none have provided reasons, I did. I also did not say they were better, as I have no experience with DVS.
The dyno figure seems high that "Envy" provided for -5s, coming from a qualified mechanic that has built a few. In fact, one of my builds is going to JEM next week that is extremely similar to what you have, hence the interest. Also, from past experience there is a lot more to a good tune than just an outright Kw figure. My intention was to draw the focus away from the outright figure, as this often leads to disappointment when there is no longevity factored into the tune for a street car where your expected outcome "is not 460kw but higher" on that set up.
The intention was to assist - the responses make me wonder why I bothered in the first place. Welcome to SA for the new guy! :/
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
