Hi, my r32 (rb20) has a high flowed r33 turbo, front mount and a 3.5 inch cat back the actuator in the high flow is at 14psi.
I want a turbo that fully boosts by 2500 - 3000 ish and pulls harder than the high flow if I got it nistuned and bought a 3 inch full exhaust plus smaller turbo would that do it? Help me please or should I sell it and buy something else?
Edited by Barrellboy
https://www.sau.com.au/forums/topic/431296-more-response/
  • Replies 50
Posted Images
the nistune will help you out no matter what you do with Turbo's
There's a series of supporting mods you haven't mentioned in your post. So I assume you only have what's mentioned.
Just buying a smaller Turbo won't help by itself.
When you say buy something else you talking a completely different car ?
https://www.sau.com.au/forums/topic/431296-more-response/#findComment-7001734
By something else I mean a different car probably a wrx
A mate took me for a drive in his sr20 180sx and it pulled much harder than my 32 and was coming on boost soo early like 2600ish.. he had pon cams, tune, fmic, 3 inch exh and injectors. Can I get that low response with a 20 mine comes on at 4200 ish and pulls no where near as hard as his 180
https://www.sau.com.au/forums/topic/431296-more-response/#findComment-7001748
usually if its just a run off the mill highflow it probably isn't specced up to be responsive.. personally im not much for bitsa turbos. Do you have any exhaust leaks? what condition is the motor? ie compression. Can you get your hands on a stocker rb25 turbo?
https://www.sau.com.au/forums/topic/431296-more-response/#findComment-7001764
I don't know the compression but it generally feels like it runs well and came from a good family who imported it and didnt drive it too hard ( I know this) no exhaust leaks either. I could buy a stocker 25 turbo off gum tree but that wouldn't get me close to the response of the sr20 would it? The sr20 also has the stocker t25 turbo...
https://www.sau.com.au/forums/topic/431296-more-response/#findComment-7001778
I think you'd need more cubes, RB30et would hammer.. just my opinion
http://www.skylinesaustralia.com/forums/topic/423299-sa-rb30et-engine-package-240kw-motor-hd-clutch-box-etc-2500ono/
Edited by AngryRB
https://www.sau.com.au/forums/topic/431296-more-response/#findComment-7001792
a tune helps infinitely. Particularly if you are willing to lean on it a bit and push the boost, esp with an electronic boost controller.
take it to Garage 101 for a nistune on the ecu and tune. I doubt you will be disappointed. Per4manz are also a damn good turbo shop so unless that turbo was highflowed for a different vehicle in mind from the technician (i.e. R33) you will be good to go hard on not much more budget...
P.S. to get a car that pulls hard and makes full boost under 3000rpm is pretty much a holy grail (unachievable essentially) and will take a very good condition motor with a very good turbo setup and associated mods ($$$).
In an RB20, yeah, pretty much impossible.
Edited by jjman
https://www.sau.com.au/forums/topic/431296-more-response/#findComment-7002124
Would even worry bout a wrx, they are not even worth comparing, its like oranges and apples.
To get decent response witb rb20, get a electronic boot controller, a aftermarket ecu, nistune is good value for money, and budget and get a tune, the tuner can bring the boost on abit earlier with the electronic boost controller so that can help, and with the turbo situation go look for a hks 2530, can make up to 230-240 kw, with excellent response, or a hypergear or a highfliwed r33 with the op6 rear housing. Ive been through the whole situation before so if i were you id be going the hks 2530
https://www.sau.com.au/forums/topic/431296-more-response/#findComment-7002295
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
