  • 2 months later...
I have made a boost leak tester and plan on seeing if there is any leaks. And to avoid killing myself with compressed air or doing damage to my automobile, Can someone give me a run down on how to safely do this, where to put what? thank you.
Its quite simple really, take off your intake pipe and stick the fitting on the end on the end of the turbo and turn on your air compressor and listen for leaks. In regards to pressure I usually test with around 40psi to know that it will definately not leak at what I run which is 20 although had accidently done it at 90psi once and still had no leaks.
Gave it a try didn't get any pressure...?! Using a 12v tyre compressor, How long would these take to build the pressure needed? Should I just let it go longer
I attached the BoostLeakTester to the pipe after the AFM, which goes to the turbo inlet. Is this ok? Do I have to go directly on the turbo inlet?
I have tried with a 12v pump and it's pointless unless your system is already really well sealed. You really need a compressor or if you dont mind the hassle drive to a servo use their air pump find leaks then take back home and fix
I've read a heavy duty 12v compressor is fine, I was thinking that I will remove the intake pipe, Did everyone else remove the whole pipe to turbo
don't believe everything you read.
If you can hear a leak and can't find it, check the dipstick.
Any more than 5-10psi is overkill. As long as it holds pressure and doesn't drop straight away, be happy.
http://www.turboboostleaktesters.com/servlet/StoreFront
I did my test with with the "tester" attached to the AFM inlet, i.e. using the stock rubber inlet pipe. It doesn't split, or leak. Keep in mind that doing it this way means that you fill the cam covers with pressure too (as the crankcase vent goes to the inlet tube). So any leaks in that area (not normally pressurized like this) will show up.
A 12V compressor will be fine. The voltage the compressor runs on has nothing to do with it. If it can fill a car tire with air, it can pump 15-20 PSI into the intake. Albeit, maybe a bit slower than a "big" compressor that can run at 100-120 PSI (like mine does).
If your getting no pressure build up at all (even 1 PSI?) then you have a leak. Find it, fix it, and test again until the system can hold pressure for a reasonable amount of time.
^ EDIT: Having the oil filter cap off will bleed out all the pressure, as your using the stock inlet pipe pressurized, so all the pressure will bleed out the crankcase vent hose, and out the oil filler cap. When mine was pressurized, when i took the filler cap off, it made a nice woosh sound and the pressure went to 0.
Edited by Shoujiki
Interesting. Maybe the oil filler cap off was my problem, And not giving the 12v compressor long enough to build the pressure. I will give it another go tomorrow through stock inlet pipe. (stock inlet pipe looks a bitch to remove)
Edited by dyl33
You will need a compressor with a fairly large air reciever if you have any leaks worth repairing. 20psi should be fine.
This was my point. Had some major leaks that were too large for the little 12v pump to be able to show up because it couldnt get any pressure in there. Hooked up to compressor and they became apparent very quickly
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
