  • 2 months later...
I have made a boost leak tester and plan on seeing if there is any leaks. And to avoid killing myself with compressed air or doing damage to my automobile, Can someone give me a run down on how to safely do this, where to put what? thank you.
Its quite simple really, take off your intake pipe and stick the fitting on the end on the end of the turbo and turn on your air compressor and listen for leaks. In regards to pressure I usually test with around 40psi to know that it will definately not leak at what I run which is 20 although had accidently done it at 90psi once and still had no leaks.
Gave it a try didn't get any pressure...?! Using a 12v tyre compressor, How long would these take to build the pressure needed? Should I just let it go longer
I attached the BoostLeakTester to the pipe after the AFM, which goes to the turbo inlet. Is this ok? Do I have to go directly on the turbo inlet?
I have tried with a 12v pump and it's pointless unless your system is already really well sealed. You really need a compressor or if you dont mind the hassle drive to a servo use their air pump find leaks then take back home and fix
I've read a heavy duty 12v compressor is fine, I was thinking that I will remove the intake pipe, Did everyone else remove the whole pipe to turbo
don't believe everything you read.
If you can hear a leak and can't find it, check the dipstick.
Any more than 5-10psi is overkill. As long as it holds pressure and doesn't drop straight away, be happy.
http://www.turboboostleaktesters.com/servlet/StoreFront
I did my test with with the "tester" attached to the AFM inlet, i.e. using the stock rubber inlet pipe. It doesn't split, or leak. Keep in mind that doing it this way means that you fill the cam covers with pressure too (as the crankcase vent goes to the inlet tube). So any leaks in that area (not normally pressurized like this) will show up.
A 12V compressor will be fine. The voltage the compressor runs on has nothing to do with it. If it can fill a car tire with air, it can pump 15-20 PSI into the intake. Albeit, maybe a bit slower than a "big" compressor that can run at 100-120 PSI (like mine does).
If your getting no pressure build up at all (even 1 PSI?) then you have a leak. Find it, fix it, and test again until the system can hold pressure for a reasonable amount of time.
^ EDIT: Having the oil filter cap off will bleed out all the pressure, as your using the stock inlet pipe pressurized, so all the pressure will bleed out the crankcase vent hose, and out the oil filler cap. When mine was pressurized, when i took the filler cap off, it made a nice woosh sound and the pressure went to 0.
Edited by Shoujiki
Interesting. Maybe the oil filler cap off was my problem, And not giving the 12v compressor long enough to build the pressure. I will give it another go tomorrow through stock inlet pipe. (stock inlet pipe looks a bitch to remove)
Edited by dyl33
You will need a compressor with a fairly large air reciever if you have any leaks worth repairing. 20psi should be fine.
This was my point. Had some major leaks that were too large for the little 12v pump to be able to show up because it couldnt get any pressure in there. Hooked up to compressor and they became apparent very quickly
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
