Hello everyone, I thought I would share, I had my cambelt done today at the garage they decided not to replace the water pump as it appears to be okay. So they got it all done and took for a test drive and the water pump snapped where it connects to the fan. Ruined radiator fan and trans cooler.
Lesson learned today.. Always replace water pump lolpost-119800-0-03946500-1379052903_thumb.jpg
https://www.sau.com.au/forums/topic/431786-rb25de-waterpump-blew-to-bits/
Wow! That's the first time I've seen that. I would be hesitant to go back there. It's really worth replacing the water pump, idler, Tensioner and cam seals when it is all apart, especially when you are paying someone else to do it.
The waterpump is driven by the fanbelt not the cambelt and before i took it in the fan belt was pretty tight, I think that maybe they didnt install it correctly after inspecting it and it got jammed i dont know how else it could break there.
They are going to replace the broken parts (hope they dont charge me for it) I will see how it turns out when i pick up on monday
Wow that would've sounded horrible when it went. Definately getting a pump change when the timing belt is replaced. :O
I recently did my ancillary belts and even though my fan belt was tight, I had to tighten it again to stop squealing.
Kinda makes you wonder just how tight is overtight.
I had a substantial piece of the water pump snap off underneath the shaft. I was freaked out too.
Timing belt was replaced months ago.
So yeah, I believe it. Looked like the casting had a hairline crack.
But you have to take off all the ancillary belts to do the timing belt ;)
Or possible the shop used a breaker bar and cranked the car to crack the nut but screwed up and cracked the water pump.
Slight chance?
Big chance! Even if the water pump was a cheap n nasty casting it didnt "blew to bits"!
Its had a lot of force put on it and its been broken
Edited by StevenCJR31
I would never do that - just put the car in gear and use some of the man power to torque it out - cranking the car is so bloody dangerous i reckon!
I always crack the nut by cranking it over. It only takes a split second to do it, just make sure the brake bar is suitable. My car is an auto so the put it in gear thing won't work.
Why are they cutting corners? Sounds like a shit shop who doesn't care. They also caused this. I changed my water pump when I did my belt not because it needed to but more the might as well factor.
Also I never needed to crank to crack the nut. Big breaker bar to take it off and properly torqued on. I'd also bet they used a rattle gun or just guestimated the torque when putting the nut on the crank.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
