Hi all. Im not after a swoosh or a fluter, I just want a good performer.
My std one has a hole in the bottom of it (its supposed to be there) but it leaks like a sieve for some reason.
any one used an after marker one that has been good with no leaks? Needs to be good for upto 20 psi.
the bov has the same pressure applied to either side of the valve + a spring holding the valve shut. So I don't really know how it would leak unless the unit wasn't sealed properly or the gasket is a bit old.
I run the Kompact, other than having no adjustment and needing to buy springs from Turbosmart for fine tuning the noises out, they are a very good product. Mine has been flawless for years.
  • Like 1
stock rb25 bovs also have a small hole for some reason. It leaks when you pressure test the system, but I can't see how the tiny hole would have an impact on the amount of air the engine uses when under high boost.
Mine gained 4psi on the dyno with the hole blocked. What a waste of boost. :P
It is there to help smoothen out the transition from boost to cruise, good tuning can help with this too, so the hole isn't really required. It is easy enough to try, as you can remove the grubscrew if you don't like it. (or drill a smaller hole through the grubscrew to fine tune the amount it bypasses)
yer, I have solved a number of issues, just from blocking that hole. fixed slow to boost issue, surge and creep issue, (which I thought it was a waste gate issue) flat spot after 4800 and before 6000 issue. low idle issue. sooo many thing were happening just because of that stupid hole. I fixed it (temporarily) with elect tape! I will get a gtr one I think. or a compact.
thanks heaps for all the info!
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
