haha, yeah i was fooling around trying to get a decent car, some asshole smashes it out from next to me and knocks me over, gets out, pulls his gun so im like f**k that, bam bam bam!
starting to think that making a Teamspeak server might be good - f**k off the ingame chat and use something that's crew-only :P
  • Like 1
i need 360 guys!
im a proper billy no mates.
all the people i team up with for missions are shit and i end up doing it all my self, and getting an equal share of the kesh.
which is bullshit.
hit level 7 last night. im now a crew monkey.
theres a crew-only chat setting in the main menu under audio. farkin lifesaver.
did some racers with manuel. it was pretty fun (i hope it didnt look like i rammed you into oncoming traffic with the dirt bikes :P, it wasnt intentional)
so far made a little bit of money and almost level 6. So far spent about $15-20,000 on tatoos. still a lot to unlock and dosh to spend.
Haha Leroy that was a classic when I just went head on into the car. Your guy looks proper bad ass with the tats and no shirt. What's the go with the head phones lol
lol Dr Dre headphones are for gimps, my guy only wears proper ear muffs haha
+1 for shirts being too expensive when saving $5000 for a single tattoo :P
I want that much money! lol
Sounds promising for wednesday when I get home. Should have half decent online gameplay by then. Then I have to start playing F1 2013. Why can't they bring games out at different times!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
