was lulz...except you killed me, i was in the car dodging your turrent
yeah its kinda hard to drive at first...i was trying to cover you but didnt work out so well and im not sure if was server or my connection but it kept stuffing up and then u dissapeared
i couldnt get into the crew stuff after that either
Hello 10 car garage
Finally got the GTR look-alike and bombed it up a bit. Only had a 2 car garage and it was already full, was just about done saving for a sick apartment then got this :)
Now to save for a private plane lol......... Nah, time to fill the garage :)
stole one of the Ferrari lookalikes, forgot you couldnt claim it as your own :(
anyone changed their plates on the iFruit app? I've changed mine but they are still the same as they were before.
basically the only reason I got the app. The chop stuff is annoying, The dog always wants something, f**k!
same..
set them.. got nothing...
shut up dog.
If you sign up for the Rockstar social club thingy you get the R35 GTR for free :)
but ive been signed up for years? we where promised this and a free garage. i got nada.
same, wheres my free gtr?
1) Go into Phone
2) Go to internet
3) Go to travel & Transport
4) 3rd shop down (cant remember name - something exotics)
5) GTR look-a-like is on the first row, ELeggy RH8 or something.
Buy it as it should be free ;)
I'd advise against, it spawns at the closest airport, which could be miles away. Not worth it...
Stick to quick cars ;)
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
