ROCKSTAR get your shit together..
3,000,000,000.00 reasons they wouldnt give a f**k unfortunatly.
nah hopefully they get it working properly but yeah, spend waaay to much time loading and trying to get people together, if everyone was held in a private server it would be so easy
also had great fun on the servival, would have been better if my earpeice didnt dissconnect and i could talk a bit more.
taking out choppers with the sniper is awesome.
heavy sniper is awesome.
cal,missjaboo and i have a private but you didnt accept friend request so couldnt add you. Once the rockstar crapola is back up we can add everyone from the crew without needing to add on PSN
haha
yeah, usually I can go to crews --> view members --> everyones name shows up + offline/online
I've never gone further then that but I assume thats where you invite to your session. This was the bit that I couldnt get to work last night. If anyone is going to be on this afternoon we can try again to try and work out the way to do it etc.
Suprising how much money/xp you can make just by continuously doing missions/races etc. Want to do some GTA Races, they are pretty fun. Did one with tanks a while ago. Basically like a normal deathmatch, first one to 10 kills wins, except you use tanks instead of guns lol. Great fun.
Someone with the highest level should be able to get people involved in some of the more advanced missions which will give the most money. Also doing some of the better jobs 'titan of a job' and whatever the one where you have to steal the chopper from the army base is
I'm working on my car this morning but planning on being home around 3ish if anyone wants to try a crew session then
Ahh had good moments last night. Survival and shooting choppers down with the heavy sniper is gold.
When GTA5 got updated recently did the earning of rp and $ change? Cause it's like we hardly got anything compared to a few weeks ago when I would get plenty. Can anyone clarify this?
yeah couldn't get into seeing crew members online last night, had to wait for invites or else 'join crew members' usually ended up with DVDDDD or emmadamo and missjaboo ... freakin emmadamo you smashed me in the head with your gun and killed me, right after i pumped a guy who was trying to kill you!
otherwise, was real fun.
also sorry to the guys who i failed on survival last game last night, was being silly and thought i could take last guy out with sniper...ahahaha
oh and add me as friends guys, kirasuran
dont know what im doing tonight but may jump on other people are online.
you're pretty good at the game Kirasuran. thought you were a random on like level 101 or something like that other dud that was in the drain race.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
